'02 ES300 UnderHood Lighting
Old 07-02-09, 05:18 PM
EJC
EJC's Avatar
Default '02 ES300 UnderHood Lighting
Last week I put CCFL bulbs in the trunk. Here's the link
https://www.clublexus.com/forums/es3...-in-trunk.html
Liked it enough to put some under the hood. I thought it would come in handy on the road at night. The results were great!
I removed a couple of the Trim plugs that hold the hood liner in place. 1 went flying and was replaced for $1.60. I mounted the bulbs on the metal behind the rubber seal at the front of the hood. First I used the velcro that came with the bulbs, but wasn't confident they would hold so switched to silicone seal. You can see the tape holding them while the silicone sets.
I seated the power supply near the bulbs under the hood insultion with velcro. It is not visible in the pic. The wire is on the surface under the hood insulation, then I routed it into the hood brace and out the hole near the strut.
And then under the plastic trim:
From there to the Fuse box. I tapped into the Horn Fuse (10amp).There is a ground lug right behind the air box, wasn't that convenient.
I also placed an on/off switch in the circuit and seat it just under the strut brace. I was tempted to use a mercury typeswitch to have the lights come on when the hood was opened but we don't do much mileage on this car and the hood is usually up in the garage and the car is on a battery tender.
Some shots of the lights in the darkened garage:
Old 07-03-09, 12:09 AM
swifty562
swifty562's Avatar
not bad... i planned on doing to my 92es300 and 2000es fully LED =0
Old 07-03-09, 05:42 AM
Slooooooow
Regional Officer - NTL
Slooooooow's Avatar
Cool
Nice mod. Ensures that you'll be shutting the hood ever so gently too.
Old 07-03-09, 06:48 AM
trukn1
NELOC Mod
trukn1's Avatar
Looks really nice.
Old 07-03-09, 08:24 AM
Pyroibw
Pyroibw's Avatar
wow, looks very good. i did the same thing a while ago, but with cold cathodes, bright as hell
Old 07-05-09, 06:42 PM
MrGalione9
MrGalione9's Avatar
nice, must admit... do have a question though... the suspension bar? where'd you get? in dire search for 1
Old 07-05-09, 06:53 PM
DixonPai
DixonPai's Avatar
very nice, it looks very helpful at night
Old 07-05-09, 07:19 PM
EJC
EJC's Avatar
It is stock, check with Lexus or the junk yards
Old 07-06-09, 06:54 PM
rlx101
rlx101's Avatar
could you please tell us model/brandfor the bulb and where you got it from? Nice & Clean install. Congrats!
Old 07-06-09, 07:15 PM
EJC
EJC's Avatar
I got them from an Amazon Seller - Moddersmart - 888-333-4942
They don't have any listed on Amazon, but you could call and find out if they have them in stock.
I have seen other sellers on EBay and Amazon with them
nsghtbrwry
04-03-17 12:54 AM
ExKoukiS14
02-14-12 11:00 AM
bqLS430
02-11-11 09:18 PM
GreenGrass
04-19-09 07:18 PM
theodores
Maintenance
11-03-05 06:56 AM
Quick Reply: '02 ES300 UnderHood Lighting
