ES300 Subwoofer...
Old 01-07-10, 08:19 AM
PFB
PFB's Avatar
Originally Posted by angmedic91
I think it sounds better than the OEM, to the point it makes the third brake light/speaker grill rattle. I need to stick some Dynamat underneath that grill to deaden the rattles. Then again nothing compares to 2 10" or 12" subs in a box. But better than OEM.
Try Velcro. Should work, and is easily removable should you ever need to change out the Break light.
Phil
Old 01-07-10, 09:25 AM
angmedic91
angmedic91's Avatar
Originally Posted by freestyle
if you dont mind me asking how much as the JL sub? how does it sound compared to the stock nakamichi? also do you have a link to the sub? and was it a direct replacement?
I believe I paid $70.00 for the JL sub, but it was a clearance item, they dont carry it anymore. The link I provided is the closet sub they have to the one I bought, notice the RMS starts at 35 watts
http://www.crutchfield.com/p_1368W1V...owAll=N&tp=111
Its not a direct replacement, in some regards it is, but you have to cut out the old OEM sub from it's bracket which is also used to keep the third brake light/speaker grille snapped in place on the rear deck.
Old 01-07-10, 08:37 PM
Ariyanna
Ariyanna's Avatar
What do you think about this one?
http://mobile.jlaudio.com/pdfs/6_8W0_MAN_pages.pdf
Old 01-07-10, 09:18 PM
llcoolpass
llcoolpass's Avatar
the impedance varies, so what happened was during a certain note, or loudness, the impedance went below what the amp was designed for. the suggested VrmsI for the speaker [watts] isn't exactly correct way to match up a speaker to the amp.
Old 01-07-10, 09:27 PM
Ariyanna
Ariyanna's Avatar
So its a safer bet to get a 4ohm or 8ohm subwoofer?
Old 04-12-10, 10:27 AM
IsPro300
IsPro300's Avatar
Ok i have a 2002 es300. The "sub" in the back says pioneer on the bottom. Does anyone one the specs on the amplifier if there is one? Also, what size is the sub in the back, 8 in?
Is the entire system pioneer? Thanks for the help in advanced!
Old 04-12-10, 10:44 AM
AndyG
AndyG's Avatar
Do only later model ES's have this sub? As in, my 1995 doesn't have one does it?
Old 04-12-10, 12:27 PM
calichris
calichris's Avatar
http://cgi.ebay.com/JL-AUDIO-8W1v2-4...ht_2023wt_1167
Old 01-04-11, 12:21 PM
dstone0423
dstone0423's Avatar
Default Lexus Subwoofer
Can you change out the 8 inch sub with another 8 inch sub if the OHMS are different? The factory is a 10 ohm and all I kind find are 8 ohm?
Old 01-06-11, 09:44 AM
dcapo
dcapo's Avatar
ya, 8" sub is no good 4 ya, makes lil difference compared to enclosures, i have tried modifying an 8", then with a 10" but it wouldnt fit cuz of my sub box which i rather keep cuz that **** ***** way better
i created a wood template for 10" using the stock 8" plate, it would stick down and the box wouldnt fit cuz i have faced towards the engine with the lil bac door open
Old 08-03-11, 02:35 PM
GINGERCOVE
GINGERCOVE's Avatar
Originally Posted by mrchacon
98 es300...
subwoofer in the back under the 3rd brake light blew... what size is it and how can i replace it? it there a certain sub i need or will any work?
Pioneer.... works
Model... ts - sw841d and 8 inch sub woofer... Love it and under $ 200.00 installed...
in Omaha
Old 08-03-11, 02:37 PM
GINGERCOVE
GINGERCOVE's Avatar
read deck speaker... 8 inch sub woofer. Just had a Pioneer model ts-sw841d
installed for under $ 200.00
Cannot believe who much better and Cheaper .......Now I can go to Disney
c b
Old 08-03-11, 02:44 PM
Megafast13
Megafast13's Avatar
Don't understand why you guys are putting so much effort into getting a replacement. Just put a box in the trunk and snip the original sub wire. Also the pen 8" is pathetic lol
Old 08-03-11, 03:08 PM
ZeusES300
ZeusES300's Avatar
I had the same problem on my sub, it blew and i replaced it with a brand new one expensive tho here's the link if your interested http://www.lexuspartsnow.com/Page_Pr...ctionID=4&isBi
Old 08-03-11, 11:12 PM
GoodRevs
GoodRevs's Avatar
Ok So I read through this thread and I still can't figure out what sub works in 97-01 ES's with Pioneer sound systems. I've installed a Pioneer nav unit with alot of add-on's but I've always thought the sub sounded weak. I don't want a box in the trunk, I just want to straight up replace the stock sub with something that gives more bang without frying anything in my car.
Quick Reply: ES300 Subwoofer...
