Headlight Aim 93 ES300
Old 03-23-09, 06:39 PM
tomstep2
tomstep2's Avatar
Default Headlight Aim 93 ES300
Hello CL,
I just replaced both front turn signals in my 93 ES. In order to replace them on my gen, you have to remove the headlight assembly. When I put it back in everything looked fine. When it got dark out, I noticed my headlights were not shining down the road as far as they used to. I checked the little bubble level under the hood and they are definitely pointing too far down (not level).
Does anyone know how to properly adjust the headlight aim? If so, would you please explain?
Thanks!
Old 03-23-09, 10:53 PM
eyezack87
Camry ConeKiller
eyezack87's Avatar
Right at the back of the headlight, somewhere near where you put the bulbs in, there is a rod that fits an 8mm (I think?) ratchet thing (name escapes me currently) and a normal Phillips screwdriver head. Twist that to make it go up or down
jboyle
10-20-18 07:46 AM
harrisbaig
09-26-18 07:44 AM
Quick Reply: Headlight Aim 93 ES300
