Oil in #1 cylinder on es300
Old 10-28-08, 02:51 PM
tim_man
tim_man's Avatar
Exclamation Oil in #1 cylinder on es300
Hello All,
the year of my es is: 1993
the problem: oil fouling of #1 spark plug.
I have terrible city gas mileage, when i get on the hwy my gas gauge goes back up to I beleive the actual spot. It also is running like it is missing somewhere. I put it on the code reader and got 52 or 55, but that code stopped coming up once i switched to 91+ gas. Can anyone help me with this issue?
Thanks in advance
Old 10-28-08, 09:38 PM
llcoolpass
llcoolpass's Avatar
did your valve cover gasket leak oil into that cyl?
you do a compression check? you could have valve stem seal leak or piston ring issue
what codes do you have? I know 52, but what are they?
the gauge and gas mileage part was very convoluded. I take it you have bad fuel economy. this does fit in theory with the oil leak into cyl 1.
Old 10-29-08, 08:08 AM
tim_man
tim_man's Avatar
I haven't tried the compression test as of yet,
yes very bad fuel mileage getting about 210.4 a tank.
Code 52 is knock sensor curcuit i believe.
I will get the test done and will respond once done
Thx
Old 10-29-08, 01:20 PM
goldlexus9
goldlexus9's Avatar
Default I need a obd 1 scanner
Originally Posted by tim_man
Hello All,
Thanks in advance
what scanner do you have I need 1 for my 1994 lexus es 300.Please let me know.Thanks
Old 10-29-08, 08:55 PM
llcoolpass
llcoolpass's Avatar
Mine is made out of .. well I dont know, but it costs nothing. It's a paper clip.
Old 10-30-08, 11:09 AM
tim_man
tim_man's Avatar
I went and got it checked at a local shop that did it for free.
The paper clip method also works.
Old 10-30-08, 12:44 PM
llcoolpass
llcoolpass's Avatar
So, what is wrong with your car?
Old 10-30-08, 02:08 PM
tim_man
tim_man's Avatar
it is not running correct, putting hand over tail pipe I can tell it has back pressure some where in the system. So far i did a further look at the rvc and see that it has a leak, the only plug that is getting fouled is plug 1. it feels like it is not running on all six cylinders until i get her up to 60 - 70 mph that is when she is ok. And my gas mileage is alot better on the hwy. in the city the needle drops from 3/4 to 1/2 just regular cruising (maybe FPR not working correct) any clues?
Old 11-12-08, 07:34 AM
tim_man
tim_man's Avatar
Problem solved.
I had a bad injector in #1 cylinder.
Thx everyone
Och
11-06-12 08:01 AM
Elysian
03-09-12 09:26 AM
L's TLS
03-29-11 06:49 PM
CitySlaka
03-10-11 04:36 AM
TunerLexx
Performance & Maintenance
03-22-10 10:47 AM
Quick Reply: Oil in #1 cylinder on es300
