1999 es300 cant rev past 3-4k rpm
have a 1999 es300 that cant rev past 3-4k rpm
couple weeks ago the car engine light popped up and it would stop going past 3-4k rpm, on the highway it cant speed up... im assuming this is limp mode ?
got the code read, came out to be knock sensor bank 1, decided to replace both of them. cleared the code, drove a few miles and check engine light came back on. this time reading MAF sensors (mass air fuel ratio) on bank 1 sensor 1 (manifold sensor, infront of engine).
Could that be the reason? I was told the MAP sensor (air intake) could also be bad?
My Car is doing the same thing can even drive in regular traffic as it will accelerate very very slowly. I think my problem is a bad ecu as it will not give anycodes, yet the check engine light is on. If you find out please post. I will do the same. I am also wondering if my cat is clogged not letting the air through and causing it to choke. will post when I get it fixed. Any ideas welcome!!
Kauz
26
12-11-14 12:15 PM
