TPMS Installed on '01 ES300
Old 02-24-08, 10:08 AM
MASH835
MASH835's Avatar
Here is the tel wire.
(you can check this wire with voltmeter by connecting positive terminal of the voltmeter to this wire and negative terminal of the voltmeter to the ground, you will find there is 12V and when you remove the Tel fuse in the engine fuse box there will be no voltage.)
Old 02-24-08, 10:11 AM
MASH835
MASH835's Avatar
I soldered the red wire from the TPMS receiver module to the tel wire for best connection.
Old 02-24-08, 10:12 AM
MASH835
MASH835's Avatar
Place the terminal back in the connector and lock the terminal retainer back again then place the wire connector back to its place.
Old 02-24-08, 10:14 AM
MASH835
MASH835's Avatar
Terminal placed back in the connector.
Old 02-24-08, 10:15 AM
MASH835
MASH835's Avatar
Connector placed back.
Old 02-24-08, 10:16 AM
MASH835
MASH835's Avatar
For the black ground wire (from the TPMS receiver module), I just soldered it to this ground wire terminal and then put tape on it as the pic.
Old 02-24-08, 10:22 AM
MASH835
MASH835's Avatar
Lastly for the switched power wire (orange wire from the TPMS receiver module), I just used a 15A access-a-fuse from http://www.accessafuse.com that I have from long time and connected the wire to the fuse and put it in place of power outlet fuse in the fuse panel.
(Note: in this pic I am also using the access-a-fuse for my fog light mod, so I soldered the orange wire to the green wire in the pic and connected them to the fuse)
Old 02-24-08, 10:24 AM
MASH835
MASH835's Avatar
Finally, Put the cowl side trim back to its place after making sure you have good wire connections, routed and fixed the wires in good place.
Follow the TPMS manual on how to first start the system and perform a diagnostic check, program wheel locations, set warnings, set display color, etc.
Old 02-24-08, 10:28 AM
MASH835
MASH835's Avatar
Another Pic.
Enjoy.
Old 02-24-08, 11:43 AM
RXGS
RXGS's Avatar
very nice where are you located canada?
Old 02-24-08, 07:55 PM
lexusk8
lexusk8's Avatar
Excellent write-up on the TPMS install! I believe this is a first I've seen successfully installed on an ES300/330. I will definitely reference this thread in the ES DIY master thread stickied at the top
Once again, great job!
Old 02-25-08, 05:55 AM
MASH835
MASH835's Avatar
I am in Saudi Arabia.
Thanks for your comments.
Old 02-25-08, 07:16 AM
Choas
Choas's Avatar
Looks really good I've seen them in the store maybe I'll have to look into it some more. Very clean as well.
Old 02-25-08, 08:01 PM
RXGS
RXGS's Avatar
o woops i saw the dash in kilometers, and canada just popped into my head, you don't do that crazy drifting in your es like what i see in the videos on youtube do you? lol
Old 02-26-08, 06:31 AM
MASH835
MASH835's Avatar
With two child seats in rear
In fact, i wont even start my car without putting the seat belt
mr29rose
07-24-21 04:40 AM
ejthomp
12-18-18 03:56 AM
4TehNguyen
11-18-17 03:12 PM
crwys
06-06-16 09:37 AM
endleesss
08-12-13 08:23 PM
Quick Reply: TPMS Installed on '01 ES300
