ES300 Coilover install Worklog
Old 08-05-07, 01:14 PM
  #31
PlatES300
PlatES300's Avatar
I've learned with the ES that it's better to install the fronts first...the coilovers won't go as low in the front, so if you put the fronts on first, you'll have a better idea of what kinda of stance you want. The rear coils will always go lower than the front (you can tuck the whole rear wheel under the fender), so adjust the stance in front first, then the rear. It will save you alot of time.
Old 08-06-07, 05:53 PM
  #32
Smitty
Smitty's Avatar
Originally Posted by Choas
Thanks man and if you get the chance could you check out the rear. Also don't meen to sound like a noob but what is the camber plate
AWWWWW Choas you're gonna kill me I forgot to measure. So sorry. It was so hot out today I was just in a rush to get it done and over with. I'll make sure I do it when I do my brakes or I'll see if I can get some specs from Ksport.
But here is a camber plate.
-Smitty
Old 08-06-07, 05:59 PM
  #33
Smitty
Smitty's Avatar
And now for the finale. The front. The fronts were so much easier than the rears. Easy to remove and put back one. Pretty much comes off like the rears but it seems so much shorter for some reason Well here goes
Remove tires of course
Loosen the brakeline holder
Loosen and remove the two strut bolts
Forgot to take a picture but pop the hook and remove the 3 nuts on the top of the strut.
Old 08-06-07, 06:00 PM
  #34
Choas
Choas's Avatar
Its cool smitty but I really could use those specs for when I fix my baby. So now that I know what a camber is what does adjusting it do and how do you do it
Old 08-06-07, 06:01 PM
  #35
Smitty
Smitty's Avatar
Smitty Tip :
If you have them where gloves. Keeps you from banging the skin off your knuckles and keeps the grime off your hands and nails. Forgot to do this for the rears. hehe
Old 08-06-07, 06:04 PM
  #36
Smitty
Smitty's Avatar
Carefully measure the height and adjustment of both coilovers to ensure they are the exact same.
Put everything back together and double check to make sure everything is tightened
Call a friend over to help you and double check your work. Sometimes its better to have another set of eyes on something. And besides you can always you an extra hand. In my case it was BernieIS
Old 08-06-07, 06:08 PM
  #37
13loody
13loody's Avatar
13loody tip:- Just double up on latex gloves when working on the car
edit- Nice work btw
Old 08-06-07, 06:10 PM
  #38
Smitty
Smitty's Avatar
Well thats it. I'm finally finished. I actually adjusted the camber and height a little more in the front. Dropped it down a little more. I must say it rides pretty well. It is stiff but not too bad of a ride. I've only driven the car roughly 5-10 miles.
Smitty Tip :
After any wheel/tire and suspension modification be sure to get an alignment. Not getting an alignment after suspension mods could result in uneven tire wear and/or even worse damage to your suspension.
I will be taking pictures tomorrow of the drop after my alignment. I'll also be taking pictures this weekend at a carshow I will be attending in Lebanon, PA. If you're in the area and not busy you should come out and kick it with us
-Smitty
Old 08-06-07, 06:19 PM
  #39
plex
1UZFE/2JZGTE
plex's Avatar
Congrats Smitty. I recomment P Tuning for the alignment. Me and Benji have the record for the lowest cars. They had to modify the ramp just for us lol. But they did an excellent job. Have fun at the show. I have summer finals.
Old 08-06-07, 06:23 PM
  #40
Smitty
Smitty's Avatar
Yeah Benji told me he had to break out the boards for ya rides lol But Good Luck on your finals.
-Smitty
Old 08-07-07, 06:48 AM
  #41
trukn1
NELOC Mod
trukn1's Avatar
Probably one of the best and most detailed writeup's I have seen here on the boards in a long while. Excellent work Smitty. Now quit teasing the people, get some finished product shots of the car and make the ES moderators sticky this thread.
Old 08-07-07, 02:27 PM
  #42
Smitty
Smitty's Avatar
Well here's a few quick pics I snapped after work today. Car was dirty so dont mind that. I'll wash her today or tomorrow and snap more.
-Smitty
Old 08-07-07, 02:54 PM
  #43
LiCelsior
Retired
LiCelsior's Avatar
looks good smitty, wish the ls400 rear struts arent so damn hard. u gotta drop the axle connections lol, and bernie looked stoned in those pics .
Old 08-07-07, 05:11 PM
  #44
Maxx941
Maxx941's Avatar
Lookin Good Lookin Good! You get it at the Stance you want yet?
Old 08-07-07, 05:50 PM
  #45
plex
1UZFE/2JZGTE
plex's Avatar
Looks good Smitty.....you and Benji need to do some shots together
Quick Reply: ES300 Coilover install Worklog
