99 es transmission problem
I have a 1999 es300 w/85k on it and am having a trani problem. When the car is cold 2nd to 3rd gear hangs and takes around 5 or 6 seconds to shift. I just had the fluid flushed last week with Type 4 but it didn't help
There is also a slight delay sometimes from 1st to second. Once the car is warm it drives well and does not fall out of gear or slip. anyone with transmission experience can help me please?
Thanks in advance
Thanks in advance
I have the same problem, but as you stated it only happens when the car is cold. The car is getting old, warming it up goes a long way. The delay from 1st to 2nd gear appears normal, as I test drove 4 different 99-00 ES 300's before buying mine.
Thanks for the info. Makes sense seeing as the trans has lines running to the outside of the radiator. I guess the water temp brings the trans temp up to "optimal" operating tempatures. If only 1-2 shifting was smoother.. Ehh Can't complain as the car is rock solid in every aspect, otherwise.
Great post I got some cold weather coming up.. so ill know what to expect.... Im def going to be installing a remote starter though to reach a higher temperature before me getting into my car.
GAGOO
RX - 1st Gen (1999-2003)
09-19-18 04:50 PM
bowen.chau
06-02-13 07:58 PM
