octane booster???
Learn what octane is first, then you'll answer the question by yourself.
No it won't do anything for you
No it won't hurt anything provided you don't average more than 10% alcohol in the gas.
Um, yea.
It doesnt make much sense either if you do the math:
Say premium is an extra $.25/gal over regular. Fill up with 15 gallons and you'll pay an extra $3.75. And a bottle of octane booster will probably cost more and do less anyway.
By the way, more octane doesnt necessarily mean more power. Putting premium gas into a Honda Civic or any car that's designed to run on regular won't make it go faster. Now, the Lexus cars usually do benefit from premium gas, but putting significantly higher octane gas won't make it magically create +25hp.
Ok i went and read what octane is it the rating at which gasoline can be compressed before it combusts. Still and of all the people here on this forum when it comes to this I trust you most Pheonix does using 93 octane in an es300 make it perform any better and/or better for the motors overall health.
Super Moderator
Listen to Pheonix
At my 1/4 mile track, I see a lot of empty bottles of Octane Booster (NOS, Restore (actually a fuel injector, too), Prestone and tons of local brands).
I asked many racers does it do anything and the answers told me it was all in their head.
Personally, I made a test of a few of these boosters and I can't say that I felt anything much in the seat of the pants or in terms of times (trying to keep fuel levels and monitoring air temperatures as much as possible). However, even then these products seem to promise a lot, and so something should have shown up if they were truly as good as advertised.
Use higher octane if your engine pings, use higher octane if you live in hot places like the desert, use higher octane if your engine has a high compression ratio, use higher octane if you're running with a turbo setup... otherwise it's not that necessary.
Simply put: no need for octane booster. What you get at the gas station is enough.
We use octane rating. You use purely ron rating. Same gas, different rating system.
Toyota has yet made a v6 engine that required the use of 93 octane. (98ron)
Super Moderator
