Keyless Entry
Old 04-09-07, 09:15 AM
insaneg0d
insaneg0d's Avatar
Default Keyless Entry
Happy Easter all!
I have a 1995 ES 300 and my keyless entry stopped working. At first I thought it was the battery in the keyfob, so I replaced it and it still doesn't work.
Has anyone encounter a similar issue? Can some please instruct me where should I look next for the root of the problem?
Thanx
Old 04-10-07, 05:39 AM
92ES5sp
92ES5sp's Avatar
Cool
Originally Posted by insaneg0d
Happy Easter all!
Thanx
This sounds kinda dumb but make sure your master switch is on
Old 04-10-07, 06:24 AM
insaneg0d
insaneg0d's Avatar
Default ???
Here's another dumb question....What's the master switch? It was working Last week then it just stopped. So maybe I messed with it without know...
Thanx
Old 04-10-07, 12:48 PM
Lexucan
Lexucanafer
Lexucan's Avatar
Thanx
There's a REMOTE OFF/ON switch to the left of the steering wheel next to the outside mirror controls. If this switch is set to OFF the button on your key will not lock/unlock the doors. I accidently turned the Remote switch off too at one time without noticing and thought my keyless entry was messed up!
Old 04-10-07, 12:51 PM
Slooooooow
Regional Officer - NTL
Slooooooow's Avatar
Yep. Bump mine ALL the time getting in and out. If you have grasshoppa legs, it can happen.
I cursed the remote system the first few times it happened. Now I automatically assume it's my fault when it happens.
Old 04-10-07, 04:01 PM
AgntTinkle
AgntTinkle's Avatar
i have a 95... and my keyless stopped working too...
i tried looking for the master switch.. but i couldnt find it
Old 04-10-07, 04:26 PM
Slooooooow
Slooooooow's Avatar
Sit in your car. Place your left hand on your left knee. Now ram your left hand in a direct line at the dashboard to the left of the steering column.
It's a little rocker switch with a white key on mine.
Old 04-11-07, 01:00 PM
AgntTinkle
AgntTinkle's Avatar
is it where the mirror control switch is?
i only have a **** to adjust the volume of the tone for the keyless... i dont have the rocker switch there... unless im looking in the wrong place
Old 04-11-07, 01:25 PM
Choas
Choas's Avatar
More to the left the **** is on the right
Old 04-11-07, 01:32 PM
Slooooooow
Slooooooow's Avatar
It's to the right of the mirror adjustment controls. I don't have a keyless tone volume ****, so that might be the difference. Interesting.
Old 04-11-07, 02:36 PM
GrahamHill
GrahamHill's Avatar
Did they all have Keyless? Mine has a keyless volume switch but I bought it used and it didnt come with a remote?
Old 04-11-07, 04:02 PM
AgntTinkle
AgntTinkle's Avatar
hmm.. so no on/off switch in my car...
time to find another solution..
and yea, i believe your car should have keyless entry, you just need a remote key
Old 04-11-07, 04:42 PM
Choas
Choas's Avatar
Did you look under the steering colum
Old 04-11-07, 05:32 PM
92ES5sp
92ES5sp's Avatar
Cool
ok maybe im retarded but what the hell is a keyless volume ****?!??!?!!!
Old 04-11-07, 05:50 PM
Lexucan
Lexucanafer
Lexucan's Avatar
You ain't retarded, you just can't hear too well !! (j/k)
The volume **** is for adjusting how loud the beep is when the car's doors are locked or unlocked. I'm not sure in which year it was added - maybe '95?
Quick Reply: Keyless Entry
