lexus es300 wheel fitment
Old 01-15-07, 03:11 PM
CLCC
CLCC's Avatar
Default lexus es300 wheel fitment
Hi CL,
Would a Dub Esinem 18x8.5 wheel size fit a 95 es300?
Old 01-15-07, 09:02 PM
MangoMan
MangoMan's Avatar
Hmmm 18" they would probably barely fit.
Old 01-15-07, 09:05 PM
LexFather
Guest
Posts: n/a
Originally Posted by CLCC
Hi CL,
Is the bolt pattern 114.3 x5?
What is the offset? It should fit with no issue once the bolt pattern is right.
Old 01-15-07, 09:24 PM
charley240
charley240's Avatar
its not really a bolt pattern problem, because a majority of standard aftermarket wheels produced are probably 114.3x5, its more of an offset thing. any wheel with 114.3x5 will fit any 114.3x5. its the offset and width that is the problem.
if you post some more info people here can help you out.
goodluck
Charley
Old 01-16-07, 06:45 AM
cino135
cino135's Avatar
glad someone asked this. was wondering if the 18 lex 05-06 rx330 wheels (hyperlite) would fit my 97 es 3?? the bolt patters , again, are the same. was wondering about recalculating the speedometer for the difference in wheel size?? is this something that will be tough to configure??
Old 01-16-07, 10:04 AM
djdoughboy
djdoughboy's Avatar
I have 18x8.5 LS430 wheels on my 92 ES and they fit just fine, I am running 18x40x225 rubber,
Ezroni (12-11-21)
Old 02-16-07, 06:38 AM
E-Z ES300
E-Z ES300's Avatar
sooo, just to be sure that i understand, i can put 18x8.5 wheels on my 95 ES300, and 114.3x5 bolt pattern is it guaranteed to fit?
Old 02-16-07, 06:43 AM
E-Z ES300
E-Z ES300's Avatar
Also what size tires would i have to get to fit a 18x8.5 sized wheel?
Old 02-16-07, 07:03 AM
MoreMGD32
MoreMGD32's Avatar
Yes, they will fit. You have the correct Bolt pattern and size seems to be ok but you need to let the wheel pros in here know what your offset is....! that is the key determining factor
Old 02-16-07, 07:39 AM
E-Z ES300
E-Z ES300's Avatar
How do i figure out the offset? Its an ebay auction and all the guy is advertising is that its a 18x8.5 wheel set and bolt pattern is 114.3x5...?
Old 02-16-07, 08:07 AM
Choas
Choas's Avatar
Hey let me know how it fits i'm getting some is350 18's 255/40/18 rear and 225/40/18 front gona put an inch spacer in the back but the 225/40/18 is only .8 inch wider than the factory setup which should not be a problem. If need be just put a spacer in you should be fine just look for ones that won't require you the change your studs completly or you might have trouble getting your winters back on
Old 02-16-07, 08:19 AM
E-Z ES300
E-Z ES300's Avatar
Thanks alot will do, Let me know how yours fit if you get yours before me
Old 02-16-07, 10:07 AM
E-Z ES300
E-Z ES300's Avatar
the wheel offset is 40... let me know what you guys think??...
Old 02-16-07, 11:03 AM
djdoughboy
djdoughboy's Avatar
Yes, im running 225/40/18s... and they fit just fine
Old 02-16-07, 11:05 AM
djdoughboy
djdoughboy's Avatar
The IS350 wheels are designed for a RWD vehicle which is why the rears are 255s... I would not suggest running staggered rims & tires on a FWD car...
Quick Reply: lexus es300 wheel fitment
