The Free Mod Series: Part VIII Electronic Transmission Controller
Old 11-11-06, 07:34 PM
Pheonix
Pheonix's Avatar
Cool The Free Mod Series: Part VIII Electronic Transmission Controller
Background:
Automatics are awesome. While the older automatics do a phenomenal job matching the shift pattern to the powerband when accelerating. You can find yourself wishing for a different gear at part throttle. Say flying through the entry of afew corners.
Low does fine for first gear. 2 can still downshift to 1st, and there is no way to hold third, or fourth. Annoying... So let's make this thing our ***** without spending hundreds on a transmission controller!
Theory:
If we can control the shift pattern. Our cars will have sex with us.
Instructions:
We'll need about $15-$20usd in basic electronic hardware.
  • 1 6-position, double pole rotary switch
  • 1 push button switch
  • 1 DPDT Relay
  • 3 15ohm 25 watt resistors
  • 4 SPST Relays
  • Around 10-15' of wiring (I used 20gauge)
For this example. We'll be using a 3vz-fe. For later transmissions, please check & understand that there may be an extra solenoid, or two that control other features. Most importantly the line-pressure. I wouldn't personally do this if your line-pressure is controlled by a solenoid instead of a throttle cable.
Shift Solenoid 1 = E10 (S1)
Shift Solenoid 2 = E9 (S2)
Torque Convertor Lock-Up Solenoid = E8 (SL)
Here is the shift pattern for S1 & S2 that derive the four gear ratios of the A540e transmission:
What we are going to do is change the wiring to the shift solenoids the control the gear selection (in drive) of the transmission. We are going to re-route the stock wiring through a DPDT relay (AKA Primary relay). When the relay is normally closed, they will pass the ECU signal as normal. When they are opened (powered). The relay will switch the circuit through a 15ohm 25 watt resistor to chassis ground. This will satisfy the stock ECU's desire to always see a 15ohm load from the solenoids.
From this point. The SPST relays (Secondary relays) will be spliced into the solenoid wiring AFTER the primary relay. When the relay is in the closed position, there will be no current to the solenoid. When the relay is tripped, it will supply the solenoid with current from a 12v supply from the common rail.
For the torque convertor, we will splice one SPST relay(primary relay) onto the SL torque convertor lock-up. Normally Closed will pass the ECU signal as normal. Open will send the ECU's current through the remaining 15ohm 25watt resistor on it's way to chassis ground. Our last SPST relay (secondary relay) will connect as the others. Spliced in AFTER the previous relay. Open will connect a 12v supply from the common rail to the solenoid.
I suggest the torque convertor secondary relay to be connected through a normal push-button switch, or toggle switch.
The primary relay's coil supply should be put together & routed to the switch area. Route a wire from each of your secondary relay's coil to your switch area. You should have four wires. A line from S1, S2, SL, and the two first relays.
Now for wiring our shift circuit!
Our 6-pole switch has 6 positions, and 14 connections. 2 connections will stand in the middle (Connect both of these together to a suitable 12v power supply.)
The remaining 12 connectors ring around the switch.
This is a double pole switch, so on any of our 6 positions, it will connect to two of the connectors. (Specifically, opposite sides.)
You can wire, to any way you wish. I chose:
Position 1 = Drive (normal ECU)
Position 2 = 1st gear
Position 3 = 2nd gear
Position 4 = 3rd gear
Position 5 = 4th gear
Position 6 = Drive (normal ECU)
To do this, from your starting position:
  1. Empty, opposite empty
  2. Connect to S1 (solenoid 1) and first relays, opposite empty
  3. Connect to S1 and first relays, opposite connect to S2 (solenoid 2)
  4. Connect to first relays, opposite connect to S2
  5. Connect to first relays, opposite empty
  6. Empty, opposite empty
You can obviously do your own variants. Such as one position holding a gear, and locking the convertor. I would keep it a separate function myself...
Ta-da! We now have the ability to successfully bypass the stock control whenever we want, and select any gear we want (Including normal Automatic features), and at the same time controlling the torque converter lock-up how we want.
Anytime the 6-pole switch is in positions 2-5. The Primary relays will swap the ECU to see ground. And the secondary shift solenoids will be operated in the manner of gear selection. The Torque convertor will operate at-will of your switch.
Old 11-11-06, 07:56 PM
vin 78
vin 78's Avatar
OMG, my head hurts
Old 11-11-06, 09:15 PM
LXMN
LXMN's Avatar
HUH?..............
Old 11-11-06, 10:10 PM
Pheonix
Pheonix's Avatar
Cool
Jesus people it's a shifter. It lets you pick whatever gear you want, when you want. And allows you to control the torque convertor lock-up ability.
Or just let the stock system handle it.
Old 11-11-06, 10:25 PM
Lexmex
Super Moderator
Lexmex's Avatar
That's beautiful
I don't use too many gears at the track with my automatic RX300, but still sometimes those shifts are sh.. and I find myself looking for the stick and the clutch and yelling dammit to myself. What Pheonix just described is an absolute work of art and well thought out.
Old 11-11-06, 10:36 PM
Pheonix
Pheonix's Avatar
Cool
Well you could do it to the RX. You would have to deal with the extra solenoids. The other one, ro two that do shifting, along with most importantly the line pressure solenoid. I'd want that line pressure maxed out in manual mode.
Old 11-11-06, 10:52 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
That's what I'm talking about baby, yeah!
I need an ES now.
Old 11-12-06, 07:16 AM
AzNMpower
AzNMpower's Avatar
I'm so confused! Honestly, with a 4-speed automatic that has large gaps between each gear, how many gears can I use? 2.
How about buy a manual transmission on your next car?
Old 11-12-06, 10:00 AM
Pheonix
Pheonix's Avatar
Cool
Because automatics are much faster & I don't care for using a clutch, or stick. I have bad joints.
Until you can trap about 120mph, you would use 3 gears in a 1/4 mile drag. Would get abit of a power jump 1/2 way through each gear if you locked the TC.
The real killer benifit is to anyone that's ever rolled in a real type of race where the steering wheel turns afew times. :P Or anyone dragging with a powerband different than stock.
O. L. T. you can do the same thing with any automatic.
Old 11-12-06, 12:30 PM
LXMN
LXMN's Avatar
I understand it to be a shifter mod. Just way too much info for my little brain.
Old 11-12-06, 06:00 PM
fdbandit
fdbandit's Avatar
Phoenix, what an awesome article. Do you have any pics of the mounted switch?
Old 11-13-06, 01:02 PM
TurboES300
TurboES300's Avatar
Smile
Wow what an awesome idea...I wish I could figure out how to do it to my ES!
Old 11-13-06, 01:21 PM
Choas
Choas's Avatar
Talking Sic
So is this mod possible on the 97?
Clean400
Performance & Maintenance
09-27-15 03:54 PM
Silvex
03-15-13 02:00 PM
fredkhaz
Performance
36
11-15-12 10:49 AM
cr8six
GS - 1st Gen (1993-1997)
08-15-11 03:25 PM
il38694
02-20-08 09:50 AM
Quick Reply: The Free Mod Series: Part VIII Electronic Transmission Controller
