still overheating...stuck like chuck...
Old 04-05-06, 06:07 PM
texaslexas
texaslexas's Avatar
Default still overheating...stuck like chuck...
okay...changed out the waterpump and timing belt--car still overheating. changed the thermostat---still overheating. no leaks, just boiling out of the resv after about 4 ms or so. wth? any thoughts?
this wkend i plan to remove the radiator and flush it all out, dont know if something is up w/airflow or what. help! unfortunately, this is my wifes car and she is starting to think i stink! lol...my ego is at stake here...
james in texas
96 300es
Old 04-05-06, 06:20 PM
mcelligott
mcelligott's Avatar
White smoke coming out of the tailpipe? May be headgaskets.
Old 04-05-06, 07:26 PM
Tammy
Tammy's Avatar
Boiling coolant in the reservoir? May consider replacing the radiator cap.
Old 04-05-06, 08:54 PM
Pheonix
Pheonix's Avatar
Cool
Ditto with MCE. It probably overheated & blew up before. At any rate it's overheat now & probably blown up. They're giving you the good advice.
Start by replacing BOTH pressure cap[s, checking the thermostat again, and THEN warm the engine up & do a compression / leak down test to see if it's blown up.
Jbarber619
10-06-14 11:17 AM
nmikmik
07-11-12 10:05 PM
Kenny77536
06-12-09 08:27 AM
Rolemodel
Maintenance
15
09-22-07 01:30 AM
actuary
Performance & Maintenance
07-21-05 04:22 AM
Quick Reply: still overheating...stuck like chuck...
