Grounding Process
Old 03-24-06, 08:17 AM
MoreMGD32
MoreMGD32's Avatar
Default Grounding Process
Hey fellas. Does anyone know how to make a grounding kit. Im an ex car audio install so i assume it wont be too hard for me to accomplish. I have plenty of 4ga. wire for the ground the car and plenty of gold 4 ga terminals. I need to know what needs to be grounded and where it needs to be grounded.
1) Battery needs to be grounded to the frame- im gonna use 0/1
2) ???? does the engine need to be grounded out? where does it need to be grounded?
3) ???? transmission? where does it need to be grounded?
4) ????altenator? where does it need to be grounded?
5) what else needs to be grounded?
Hopefully this will assist with me lag and engine response time as well as my ground loop issue.
THanks guys
Old 03-24-06, 09:26 AM
Lexmex
Super Moderator
Lexmex's Avatar
I can't do it quite right in my RX300, but the throttle body and alternator would be key points.
On the transmission, there are some holes on the top, but you will have to get a screw that can fit.
Finally, the engine block, there should be some screws that hold the top of the valve cover down in place. You can take the screw off, add the ground, and then re-enter the screw without issue.
Old 04-27-06, 01:14 PM
MoreMGD32
MoreMGD32's Avatar
can anyone provide any pictures of this process or of the completed process?
thanks guys
TheAzn
06-19-13 06:33 PM
LexISGS300
GS - 1st Gen (1993-1997)
04-15-12 07:43 PM
faceoff101
05-05-07 02:43 PM
DesertSlim
Performance & Maintenance
09-20-06 12:44 PM
ummagawd
11-03-04 10:53 AM
Quick Reply: Grounding Process
