Squeaking Belt Caused by pully?
Old 11-19-05, 04:43 PM
Ideal1267
Ideal1267's Avatar
Default Squeaking Belt Caused by pully?
My 92 es3 is making a sqeaking noise under the hood where my belts are located. I noticed a lower pulley (Crank Pulley?) is wobbling which is also cause my belt to squeak? Does this mean that my crank pulley is bad and need a new one or would something internally be causing my crank pulley to wobble? For temp. use i use belt conditioner and lubrication to relieve the noise but it only works temperarily.
Old 11-19-05, 04:57 PM
vin 78
vin 78's Avatar
Is your belt loose?
Meanwhile, you should have the pulley checked out.
Old 11-19-05, 05:01 PM
Pheonix
Pheonix's Avatar
Cool
The crank pulley bolt is self tightening. Once put on(even half way to spec) It's going to spin itself tight. The crankshaft pulley is also keyed, so it can't slip. It's also on the end of the crankshaft. If the crankshaft is warped enough to see with the naked eye, the engine is not going to be running.
Power steering, or accessory (A/C & alt) belt is loose. Replace both & check the timing belt. It & the water pump need to be replaced every 90,000 miles.
Old 12-14-05, 03:07 AM
kelseyboy
kelseyboy's Avatar
mine is doing the same crap!!
i jacked it up and took of the inspection plate, and sure enough the freakin bolt is tight, and the pulley is seperating,
talk to some lexus mechanics and this is a common problem
LEXUS PRICE IS 365$$$!!!!
screw that! I am currently looking.......
ruger
06-07-16 03:33 AM
MooJohn
SC- 1st Gen (1992-2000)
07-30-11 09:11 AM
kez
07-22-10 03:34 PM
snidehocke
Performance & Maintenance
02-11-08 06:21 PM
brit_lex
12-02-04 12:32 AM
Quick Reply: Squeaking Belt Caused by pully?
