ES330/300 DIY (do-it-yourself) & technical tips
Old 03-10-13, 06:45 PM
  #106
speedkar9
speedkar9's Avatar
Here's a quick DIY on how to change the air filters on a 4ES:
Old 04-03-13, 03:41 PM
  #107
navdeepasi
navdeepasi's Avatar
Originally Posted by DRACO A5OG
Hello Everyone!
Newbie here working on my lady's 96 ES300. I'm a Modest Experienced DIY 911 Guy and decide to DIY hers.
I read a bunch of threads about the P0401 issue " EGR Flow Insufficient" and Cold Start Issue.
Tested the VMV (Vacuum Modulator Valve or Solenoid or Assembly) it would not hold a vacuum so I went to my local Toyota Dealer and bought the VMV for a 92 Camry Toyota Part #25870-62020 $105.48 (Parts Guy hooked me up and sold it for $80) Autozone had it for $78.99 shipped in 2 days. Other places sell them for $64 or $45 but you have to wait for it be shipped and not OEM.
Prior to this I took off the VMV and cleaned it out. Still had cold start issue but when warm it started right away. I reset the CEL but the CEL came back on after 10-15 miles.
Literally 5 mintues in the Dealer's parking lot (they were not too happy about that, but no one complained) and popped in the new VMV with a 10MM socket wrench, disconnected the battery. Bingo Trouble Code Gone, Started Right Up and running 100+ miles no issues.
Hope this helps someone with like issues.
Cheers
Jim
Hi,
Do you have a step by step on how to change the VMV? I have the same issue but was told the gas tank needs to be dropped in order to fix the issue and change the solenoid.
Any help is much appreciated!
Thanks.
Old 04-03-13, 03:54 PM
  #108
DRACO A5OG
DRACO A5OG's Avatar
Originally Posted by navdeepasi
Hi,
Thanks.
Wow, it has been so long since I did, this, but it was pretty straight forward, just get the part and swap.
Are you sure it is the VMV and not the Fuel Pressure Regulator. Also How did they determine it was the solenoid? that kinda does not make sense, do they mean fuel pump?
Old 04-06-13, 05:00 PM
  #109
navdeepasi
navdeepasi's Avatar
Well I'm getting the same engine code, but I only get it when the weather is warm, it hasn't happened in the winter. And when it's the first start of the day it takes a few seconds to start up, but if I've started it up, and start the car later, it starts with no hesitation whatsoever.
Old 04-13-13, 09:13 AM
  #110
usmclibal
usmclibal's Avatar
I just got a 1998 ES300 and it has bumper damage, nothing too bad so the airbags didn't go off. However, I was wondering if anyone had tips for how to remove and replace the front bumper without effecting the airbags? Thank you! (best car I've ever owned!)
Old 06-16-13, 04:48 AM
  #111
imherenow
imherenow's Avatar
A DIY for Coolant drain and refill for 97-01
https://www.clublexus.com/forums/es3...r-97-01-a.html
Fdavis13 (09-01-22)
Old 06-16-13, 04:49 AM
  #112
imherenow
imherenow's Avatar
(DIY) 02 ES300 License Plate Bulbs:
https://www.clublexus.com/forums/es3...ate-bulbs.html
Old 06-16-13, 04:50 AM
  #113
imherenow
imherenow's Avatar
DIY: Lexus ES330 V6 Spark Plug Replacement:
https://www.clublexus.com/forums/es3...placement.html
Fdavis13 (09-01-22)
Old 06-16-13, 04:51 AM
  #114
imherenow
imherenow's Avatar
DIY Rear Door Lock Actuator
https://www.clublexus.com/forums/es3...-actuator.html
Old 06-16-13, 04:54 AM
  #115
imherenow
imherenow's Avatar
^^^^ ok i have added a few DIY from CL members. Also i have notified moderators/administrators to put this DIY thread on ES300-330 main page ALL the time so it will be easier for people to find and to keep adding more ...
Old 06-16-13, 04:55 AM
  #116
imherenow
imherenow's Avatar
DIY ES330 A/C filter change w/pics - other yrs may apply
https://www.clublexus.com/forums/es3...may-apply.html
Old 06-18-13, 08:47 AM
  #117
mamadubig
mamadubig's Avatar
My stereo LCD went out on my 99 ES300. It is a Nakamichi. I followed the instructions from this link to remove the LCD but I am unable to re-attach the LCD. I am scared id I pusg too hard I will break it. Any ideas and tricks on how to do this? Here is the link I used:
https://www.clublexus.com/forums/es3...radio-lcd.html
Any help will be appreciated.
Old 06-23-13, 05:36 PM
  #118
imherenow
imherenow's Avatar
DIY for adding mist feature on wiper arm:
https://www.clublexus.com/forums/es3...d-no-more.html
Old 07-02-13, 06:42 PM
  #119
imherenow
imherenow's Avatar
Alright guys i did this today and took only 15mins.
1) need flat panel LED
2) need long wires
connect one end of the wire to the normal dome metal piece and other end to the front map lights via underneath the roof liner and then take that flat panel led and connect to it. and thats it!!
I burned 2 times the fuse because i touched the wires together. Not good. The map lights works separately. i just didn't show it in the video
I took a video of it :
Old 07-06-13, 12:20 PM
  #120
DanStout
DanStout's Avatar
Yesterday the AC quit and all items on the bottom of the center console controls (fan controls, front and rear defroster, heat, outside temperature indication, etc.) are dead. Have looked at fuses but don't see any blown. Any suggestions?
Quick Reply: ES330/300 DIY (do-it-yourself) & technical tips
