Drag Strip Discussion about Lexus straight line racing on the 1/4 mile, 1/8 mile and top speed flats.
1/4 Mile Track Results
Old 03-29-11, 07:47 PM
DHRP
DHRP's Avatar
Default 1/4 Mile Track Results
My F is broken in now so what to do first? Take it to Atco Raceway I haven't ran down the 1/4 mile since the early 2000's with my RX-7. I was able to get 5 runs in. Temperature was 48-50 degrees.
1st run was just a trial run in auto not even Sport mode ran a 13.341 @ 108 mph.
2nd run Sport mode paddle shifting, trac ON, launch at idle. Ran a 12.929 @ 111.57 mph.
http://www.youtube.com/watch?v=bVRCZ08mjvE
3rd run Sport mode paddle shifting, trac OFF, launch at 1000 rpm. Ran a 12.845 @ 111.67 mph
http://www.youtube.com/watch?v=77H9b18mgTg
4th run Sport mode, paddle shifting, trac OFF, launch at 1000 rpm. Ran a 12.959 @ 110.61 mph.
http://www.youtube.com/watch?v=JwpL7LAerLo
5th run same as last run except I launched at 1300 rpm. Ran a 13.087 @ 109.89.
It seemed like I was losing speed as the night went on. I was shifting at the buzzer. I didn't get to try Auto in Sport mode so I'll have to head back and give that a try. I'd also like to try different launch RPM's. I couldn't get anything better than 2.0 60' times. Tire pressure was a 28psi.
Old 03-29-11, 09:16 PM
mr2fast
mr2fast's Avatar
congrats I've owned my F for almost a year and still havent made it out to the track. You can definitely get your 60' down, but 12.8 is not bad. what tires are you on? how much if any wheel slip off the line?
Old 03-30-11, 07:20 AM
DHRP
DHRP's Avatar
Running the stock Bridgestone RE050A tires. My launches were creating almost no wheel spin which leads me to believe I wasn't being aggressive enough at launch. Maybe at 1500 rpm or more I can pull a 1.9 60'. I'll have to go back to try.
Old 03-30-11, 11:26 AM
pc1990
pc1990's Avatar
Wow...I didn't know the IS-F stock exhaust sounded so good from the outside. Nice 1/4 sprints btw.
Old 03-30-11, 11:34 AM
Dv8tion388
Dv8tion388's Avatar
Some good runs, you beat the published times.
Your best bet is trac and stability off, sport mode in F paddle shift. Launching 1500-2k is ideal. I cracked a couple 1.9's stock on street tires, most were 2.0 flats. Heat soak does affect the F so keep the hood open when waiting and ditch the engine cover for the races(i know its pretty but it traps too much heat.).
~Dv8
Old 03-30-11, 01:24 PM
DHRP
DHRP's Avatar
Dv8 - I actually saw your 12.63 run on youtube the day before I ran mine and used it as my goal being stock. After my 3rd run I thought I had a shot at a 12.6-12.7 run at 112 but times just kept getting slower.
Old 03-30-11, 03:25 PM
Dv8tion388
Dv8tion388's Avatar
Awesome! Glad i made a positive impact in my short time here.
I had a couple launches that just felt slower. When launching the momentum of the stall needs to carry through. In otherwords, you dont want to sit at the staging lights stalled up to 1500rpm waiting, you want to stall, hold and release in a quick manner.
Screw the other lane, you dont have to leave on green thats only for reaction time and elimination competition. Leave whenever you want, the 1/4 mile timer doesnt start till you take off regardless of whats going on in the other lane.
Practice makes perfect.
~Dv8
TrevorR
GS F (2016-present)
30
12-16-21 04:20 PM
dontrump
08-13-16 05:18 AM
guitarguru
04-02-16 05:23 PM
scham21
02-07-14 08:48 PM
Fizzboy7
06-06-08 01:07 PM
Quick Reply: 1/4 Mile Track Results
