GRACENOTE - how to erase USB key cover memory ??
The Gracenote system have imported WRONG cover pictures for some of my mp3 files (correctly tagged with the correct cover picture) of my USB key.
And now it's impossible to overwrite these wrong pics with my correct pics....
Is there a procedure for erasing all the cover memory in my MARK LEVINSON system ???
Then I can connect again my USB key and all my MP3 sould be rescanned and the original cover (from mp3 files) will be used !
I will see the correct pics then !!!
Thank You for your answer !!
chris.
chris.
I think the only way would be to go into the navigation system Click Menu--->Setup---->General---> and Delete Personal Data. This will wipe out any saved navigation stuff, phones, and contacts just so you know. I've been told by the Tech guys at Lexus Headquarters in Torrance that you should do this delete personal data at least 3 times. They have seen some cars that don't delete everything the first time around for some reason.
I will check that !!
Any other solutions guys ???
