CT 200h Model (2011-2017)
Coils
Old 03-11-14, 11:15 AM
jalford999
jalford999's Avatar
Default Coils
Want to raise my CT200h by about an inch. Any suggestions? Have already swithed tires to the 215/50/17. Thanks for your help.
Old 03-17-14, 12:32 PM
Clutchless
Clutchless's Avatar
Received 1,096 Likes on 935 Posts
Buy a Subaru. Seriously, the only possibility may be coil overs that allow you to adjust suspension height. You need to check the specifications to see if they allow you to raise it above stock height as almost everyone buys them to lower the car. They are expensive, close to a thousand or more.
Why do you want to raise it? I have an F-sport and do not have many issues with it even though it is an inch lower than the regular model.
Old 03-17-14, 03:05 PM
whlkev
whlkev's Avatar
I don't think the F sport is lower than the regular model, should be same height
Old 03-18-14, 10:49 AM
Clutchless
Clutchless's Avatar
It is lower if you have the F-Sport suspension with F-Sport lower springs. It is obvious if you look at both. The wheel gap is much smaller on the F-Sport. If you do not believe me, check out this thread: https://www.clublexus.com/forums/ct-...t-springs.html
Old 03-18-14, 11:14 AM
whlkev
whlkev's Avatar
oh don't get me wrong, not that I don't believe you, just want to make sure everyone is on the same page
the F sport lowering springs you mentioned, as far as I know, only comes with the CT200h F sport Special Edition, it also comes with other extra F sports goodies
if you install it afterward, it doesn't make it a factory standard equipment, just like the F sport trident wheels, lowering springs and sway bars are not part of the $1k F sport package, those are count as dealer install accessories
all the other standard F sport you see on dealer lots, those are the same height as a regular CT
Old 03-19-14, 10:22 AM
Clutchless
Clutchless's Avatar
Thanks. I have an F-Sport SE and was unaware the suspension upgrades were a dealer sold/installed option. It still rides better than my old 2008 MINI Cooper S and handles almost as well, although much slower.
fiveainone
07-22-22 08:26 AM
skabei
NX - 1st Gen (2015-2021)
24
12-12-17 04:13 PM
Mikerx350f
RX - 4th Gen (2016-2022)
03-09-17 07:45 AM
ISking
Suspension and Brakes
01-09-10 01:43 PM
TrancEpimp
08-23-09 10:10 AM
Quick Reply: Coils
