hey guys, can you help real quick? wheel fitment question
12-03-13, 10:30 AM
will these fit?
VarrsToen ES2 (2.2.1) 18x9.5 +34 5x100
I've seen posts on the lowest offset thread where peepz were running 18 x 9.5 but +38, these are +34...
let me know!
12-03-13, 03:32 PM
Are you lowered? If so, by how much?
12-03-13, 08:59 PM
not lowered yet, but will be getting coilovers =]
12-04-13, 01:23 PM
The new wheels might stick out a bit.
12-04-13, 01:40 PM
if wanting aggressive fitment on coilovers you should get away with it assuming you are able to
run some negative camber, stretch a little tire, and show a little minimal love to the fenders
12-04-13, 02:25 PM
Sorry just need quick help. Anyone know if 2006 Mazda rx8 wheels would fit on my 2001 lexus is 300?
12-04-13, 03:39 PM
do you have wheel size and offset?
12-04-13, 08:03 PM
You should be able to clear fine, this was me when I had 18x8.5 +35 all around +20mm spacer in the rear
12-04-13, 08:03 PM
And just found this one too, which resemble your fitment more. This was a 18x9.5 +38 setup with+20mm spacer in the rear as well
12-05-13, 01:06 AM
Damn Doublade, you make me hate my CT.
12-05-13, 06:01 AM
check out thomas phans wheels specs on his work's..i wana say they are somewhat close to those specs
12-05-13, 11:19 AM
Quote:
Originally Posted by
Tennis100
Oh sir I'm sure yours is a lot better than mine!
12-05-13, 01:25 PM
I just hate how hard it is to find wheels you want in the aggressive offsets many of us want . . .
12-06-13, 09:03 AM
Former Sponsor
Front's will be aggressive and will require some camber bolts. I think 225's will work, but 235's may require a slight roll/pull on the fenders.
Rears will be fine, and can probably use a 5-10mm spacer depending on how aggressive of tires you end up going with, and also if you plan on rolling the rear fenders.
8UR911
Wheels, Tires & Brakes Forum
04-07-10 12:18 PM
Choiza
IS - 1st Gen (2001-2005)
11-19-09 02:20 PM
mikez
02-12-09 04:57 AM
