check hybrid system on dash
I cannot get the ready light on my ct200. Push to start, lights come on but no "ready" light. the seats are not in. the rear seat is removed.. The check hybrid system light is on. How can i find out what all is involved in that system. The dealers are no help.
I have the same problem, I have a 2012 Ct200H with right side doors damage, It doesn't want to start all the lights are on when you power up but engine doesn't start it says CHECK HYBRID SYSTEM and "!" in Triangle. It has right side seat and curtain airbag deployed as well. Any advice on getting this car started?
Thanks in advance
Thanks in advance
^^ these people had ACCIDENTS....= NO WARRANTY for repairs
Sounds like damage to the cooling system for the hybrid motor
However, I would get it towed to the dealer and call INSURANCE and PAY to have it repaired correctly
Hybrids have a safety system that will disconnect the hybrid battery in the event of a collision. If an airbag deployed, it's a chance this is what happened. You will need to have a dealer inspect and reconnect if this is the case.
This problem happens a few ways. Pulling the fuse out from under the hood can do it. Running out of fuel, messing with that orange switch. Are a few reasons. All you need is a 25 buck tech stream clone cable that can be bought on Amazon. And you done. It can reset it all day long.
gledingh (12-22-19)
This doesn't work. Hand held scanner will not reset anything.
This problem happens a few ways. Pulling the fuse out from under the hood can do it. Running out of fuel, messing with that orange switch. Are a few reasons. All you need is a 25 buck tech stream clone cable that can be bought on Amazon. And you done. It can reset it all day long.[/QUOTE]
I work for a Lexus Dealership and am hybrid certified. when I ask a question its not to give a run around. I'm here for you guys/gals.
