CT 200h Model (2011-2017)
Default the nav display to closed?
Old 10-12-12, 08:46 PM
Boatguy
Boatguy's Avatar
Default Default the nav display to closed?
Anyone know if it's possible to set the nav display to default to closed? Most of the time I prefer not to look at it so I get in the car and immediately hit the "close" switch. Can I make that the default? Probably not what Lexus wants after I paid $2K for the nav package!
Old 10-14-12, 08:12 AM
ezlivin
ezlivin's Avatar
Unable to do this on 2011 & 2012 models. Supposed to be an option on 2013 model.
Old 10-22-12, 11:04 PM
whodatninj
whodatninj's Avatar
hopefully 2011/2012 models will be able to update the navi for all the goodies *fingers crossed
Old 08-21-15, 08:01 PM
RCSimmons
RCSimmons's Avatar
Have you tried going to Menu -> Setup -> General Settings -> Auto Screen Change (On/Off)?
Old 08-24-15, 08:58 AM
UMassMike
UMassMike's Avatar
The auto change screen setting is when you're using nav and it switches back to the radio, or vice versa, but has no effect on the screen being open or closed.
Does anyone with a 2015/2016 have a screen that closes? I had a 2013 with nav that the screen would open and close, but I think the 2015 nav screen is fixed.
Old 08-27-15, 09:41 AM
ultrawtct
ultrawtct's Avatar
I have a 15 and i don't think it closes. Where would I see this option and I'll double check.
Old 08-27-15, 11:34 AM
whlkev
whlkev's Avatar
2015 model the nav is in a fixed position, it does not and will not close
Old 08-29-15, 10:00 AM
oregonkat
oregonkat's Avatar
I believe 2013 is the last year the display retracted. After that it's fixed open. If I close mine it stays closed the next time I drive, except for displaying camera if in reverse, but then closes again.
JerryWest
08-30-17 07:34 AM
Magellan
02-06-17 11:43 AM
meka2u2
ES - 6th Gen (2013-2018)
06-27-14 07:36 PM
trapstar
02-06-12 03:58 PM
cal007
HS 250h Model (2010-2012)
08-01-11 10:01 PM
Quick Reply: Default the nav display to closed?
