CT 200h Model (2011-2017)
HELP!!!!!!!!!!! 19" fitment
Old 06-09-12, 08:06 PM
mr.weather
mr.weather's Avatar
Default HELP!!!!!!!!!!! 19" fitment
just got a new set of 19" rims online
told by a member in here and got front: 19x8.5+45 225/35/19 rear: 19x9.5+50 245/35/19 setup
but when i put the rear rims on it doens't fit.... the suspension arm a on the way of the inner rims
anyone run with this spec??
right now i put the wider rims (19x9.5) at the front and running the 19x8.5 at the rear it but i am trying to find a way to fit the wider rims at the rear
any recommendation??
Old 06-09-12, 09:16 PM
SBCsx
SBCsx's Avatar
damn those are wide *** wheels and tire setup for a ct200h lol. What car are you trying to fit these wheel on? If the wheel is hitting the suspension arm then i suggest you run a lower offset. By either adding a spacer or buying another wheel setup with lower offset
Old 06-10-12, 08:23 AM
fasthuh
fasthuh's Avatar
Your cutting it close, looks like those are subaru offsets. Try getting spacers to clear the suspension arm, that offset is fairly high you might get lucky and not have to shave the fenders.
Old 06-10-12, 06:21 PM
jimmyc13
jimmyc13's Avatar
Wow man, that's real aggressive. Who told you that would fit? Those are the exact specs for a staggered setup on a G35 (I used to own one). Too bad it's a different bolt pattern, you could have sold them.
Old 06-11-12, 12:49 AM
Doublade
Doublade's Avatar
+50 offset in the back? I think thats a bit too much. shouldve done +45. You might have to roll and it depends on ur suspension. stock springs?
Old 06-11-12, 07:41 AM
mr.weather
mr.weather's Avatar
i just installed road magnet.... so not much space at the rear...
maybe i will try a 5mm spacer at the rear???
Old 06-11-12, 09:58 AM
SBCsx
SBCsx's Avatar
measure it for clearance before you buy. i think the safest before your lug nuts start to come out are 10mm spacers. After that you have to buy extended studs.
Old 06-11-12, 11:39 AM
mr.weather
mr.weather's Avatar
i have a friend can lead me a 5mm space to test it out... hope it work... or worse case i can roll my fender for alitte
any recommended spacer? or doesn't really matter they all work the same??
Old 06-11-12, 11:51 AM
mr.weather
mr.weather's Avatar
oh and do i need alignment after i lowered??
Old 06-12-12, 07:17 AM
hdave
hdave's Avatar
yes you do
Old 06-12-12, 10:32 AM
sway162
sway162's Avatar
Please post a pic...curious to see fitment with those specs.
Old 06-12-12, 12:13 PM
mr.weather
mr.weather's Avatar
here u go...
front: 19x9.5 245/35/19
rear: 19x8.5 225/35/19
will try to add spacer at the rear c does the wider rims fit at the back
Attached Thumbnails HELP!!!!!!!!!!! 19" fitment-ct-r.jpg   HELP!!!!!!!!!!! 19" fitment-ct.jpg
Old 06-12-12, 01:37 PM
fasthuh
fasthuh's Avatar
Looks great!
Old 06-12-12, 03:43 PM
BIGLU12
BIGLU12's Avatar
Default Nice
Nice work
Old 06-12-12, 07:12 PM
Doublade
Doublade's Avatar
huh interesting.
Quick Reply: HELP!!!!!!!!!!! 19" fitment
