CT 200h Model (2011-2017)
Lexus CT 200h LED Light Swap Courtesy of LuxuryMods.com! - Writeup for Puddle Lamps!
Old 06-28-11, 09:55 AM
jimmyc13
jimmyc13's Avatar
Originally Posted by LuxuryMods
That's a good question! It looks like they use a #921 bulb which is pretty much a 194 base. Depending how the bulb is positioned in the socket, we have a couple of different types we can try out.
Maybe I can meet with you again Matt to try the reverse lights
Thank you sir!
Sounds good, I nominate Matt!
Old 06-28-11, 10:56 AM
Matt_RN
Banned for Life
Matt_RN's Avatar
Okay! That's fine. When are you free, Tony?
Old 10-23-11, 06:25 PM
Nmahini
Nmahini's Avatar
Default How to change map lights on ct200h
Dear all,
Hope everyone is doing wonderful. I'm having some difficulties removing/changing the map lights. Any advice on how to remove the head control? Pictures on how to do so is greatly appreciated.
Old 10-24-11, 01:55 PM
BensCT
BensCT's Avatar
Default Exchange map light.
No need to remove the overhead unit (although it's easy). To remove map light, first look at individual light. It is enclosed in a clear rectangular plastic dome. Insert a butter knife between the plastic dome and the plastic of the overhead unit at the side where it is closer to the windshield, using the plastic dome as a leverage, pull the plastic dome out in a down and back (towards the rear of the car) motion. The rectangular plastic dome should come off.
Old 02-07-12, 05:22 PM
oneflow
oneflow's Avatar
So the lights are sweet got them from Tony. Left the puddle lights for last and i would say it's kinda tough. I shattered my mirror.
Sucks i'm sure this will be expensive to fix.
Old 02-07-12, 06:50 PM
ArmyofOne
Dysfunctional Veteran
ArmyofOne's Avatar
^not really, mirror glass is relatively inexpensive and you can replace it yourself if you know your way around with a screwdriver, allen key and a wrench. Dont let the dealer charge you $500+ until after you attempt it yourself.
Old 02-07-12, 07:30 PM
oneflow
oneflow's Avatar
So found the part
87961 8796176040
MIRROR OUTER, (LH - LEFT / DRIVER SIDE) 01 Ships 24-48 hrs $98.10 $81.59 $58.86
not to bad on price kinda makes me want to try the other and just order 2 if i fail again.
Old 02-07-12, 08:44 PM
oneflow
oneflow's Avatar
So i went out to try the 2nd one because at this point who cares. Well it came off so easy i couldn't believe it. Switched it out no problem. Not sure why the first was so difficult.
So now it's on to ordering the part after i stop at the dealer to see if they have it in stock.
Hope this helps everyone.
Old 02-08-12, 12:19 PM
oneflow
oneflow's Avatar
Just got back from the Lexus dealer they would not cover under warranty. No surprise there. They did however give me a deal on the part at $80 better than waiting a week to save 10 bucks after shipping. It looked to me like there was much more of the white glue stuff on the on that broke. I think that might have been the issue but proving that is a manufacturing issue is pretty much impossible.
Anyways likes looks sweet and car is all back together.
Old 02-11-12, 04:56 AM
jimmyc13
jimmyc13's Avatar
Are you serious? Trying to comprehend that pulling the mirror up would shatter as shown in the photo! Glad to hear it's all worked out/fixed.
Regarding that white glue stuff, my drivers side had a ton of it (it's sticky, but can't see it doing that to your mirror) and the passengers side didn't have any.
Old 02-11-12, 08:13 AM
oneflow
oneflow's Avatar
When i was pulling up and out it pretty much taco'ed in the middle. you can see the cracks that go straight across the middle
Old 02-11-12, 09:05 PM
john37
john37's Avatar
Sent an email to Tony a few days ago, no response...must be busy
Old 05-11-12, 12:08 PM
dgurvits
dgurvits's Avatar
Just wanted to thank you for this thread. i recieved my kit from luxurymods today and installed everything including the mirror puddle lights
everything went on really easily, i would say the worst bulb to fiddle with was the trunk light, i have never seen a weirder contraption, Lexus shocked me there. Anyhow, bulbs look great, hopefully they will last
thanks again
Old 05-13-12, 04:02 PM
FNFZ4
FNFZ4's Avatar
Nice. love it
Old 05-13-13, 01:05 PM
whlkev
whlkev's Avatar
met up with tony too in socal for the rear license plate LED install, the 3SMD is perfect
great guy, great product, thanks Tony!
Mavsbball
03-18-17 09:57 AM
Luffy808
02-05-17 07:54 AM
mcfancy
RX - 4th Gen (2016-2022)
07-29-16 12:55 AM
tpjc1018
06-30-14 07:29 AM
neomedic
12-05-11 09:02 AM
Quick Reply: Lexus CT 200h LED Light Swap Courtesy of LuxuryMods.com! - Writeup for Puddle Lamps!
