CT 200h Model (2011-2017)
Poll: What is the most gallons you've put in the tank
Old 05-16-11, 07:31 AM
mm767cap
mm767cap's Avatar
Originally Posted by spwolf
it is common with all new cars, but especially hybrids since components can be damaged if you run it without gas...
AMEN! You guys are braver than I. I have read a few things that suggest running out of gas in a hybrid is a BAD idea. Fact or fiction, I'm sure not going to test out the theory on mine!
Old 05-16-11, 11:34 AM
dkidwell
dkidwell's Avatar
I ran out of gas once when I was a teenager. I didn't like it. Now I fill up at 1/2 a tank.
One exception would be on a long trip and then I might go to 1/4 tank, but never below that.
Old 05-16-11, 04:54 PM
hyperme
hyperme's Avatar
I always stretch it out as long as possible. I've run out of gas 2 or 3 times since I started driving. Once with the hybrid, that's how I know how large the tank is. Oh, and I've not had any problems with it since then.
Old 05-16-11, 06:31 PM
jimmyc13
jimmyc13's Avatar
^ Why would you stretch out fill-ups as long as possible? I have 156K on my current car and I think I've only seen the light come on 4 times in the 7 years I've owned it. I never let it go below 1/4 or 1/8 of a tank.
Old 05-17-11, 04:22 AM
Bob259
Bob259's Avatar
Hate to keep bringing this up, but on newer vehicles with the in tank fuel pumps they also use the fuel as a coolant for the pmp motor. By continually running it to almost empty you are putting a strain your pump motor that will shorten it's life.
Old 05-17-11, 07:18 AM
DJTIMMYD
DJTIMMYD's Avatar
I don't think anyoone wants to purposely do damage to their car. My whole thing is why sell a car with a fuel tank rating of 11.9 gallons when the gauge only reflects 9 gallons or so? I understand having a reserve but 3 gallons is too much IMO.
Old 05-18-11, 03:50 PM
Trexus
Trexus's Avatar
Got gas at Chevron today and filled my tank with 9.321 gallons of gas. I know I should fill up the tank when it's at least the half-way mark. So far my CT is getting better gas mileage as time goes by...
Old 08-15-11, 09:33 AM
midcow3
midcow3's Avatar
Default fuel as a coolant -- very interesting
Bob259,
It is very interesting that you have mentioned a couple of times that the fuel is used a a coolant for the pump motor. I am interested in researching and learning more about this. Can you point me toward where I might learn more.
Thanks,
MidCow3
Old 08-15-11, 09:42 AM
Bob259
Bob259's Avatar
Originally Posted by midcow3
Bob259,
Thanks, MidCow3
I'll dig for some other tech bulletins I have somewhere, but here it is from Wikipedia
As engines moved away from carburetors and towards fuel injection, mechanical fuel pumps were replaced with electric fuel pumps, because fuel injection systems operate more efficiently at higher fuel pressures (40-60psi) than mechanical diaphragm pumps can generate. Electric fuel pumps are generally located in the fuel tank, in order to use the fuel in the tank to cool the pump and to ensure a steady supply of fuel.
Whole article can be found here http://en.wikipedia.org/wiki/Fuel_pump
Old 08-15-11, 03:53 PM
lexuslover
MultiTasking Mom
lexuslover's Avatar
when does the light come on? i drove down to just below the 1/8 marker and the light was still NOT on. i got too scared and filled up anyway and only got 8.3 gal.
on my two gas trips so far, i've filled 7.6 and 8.3
i'm used to waiting for the light to come on around 1/8th in the other cars, but the needle was getting pretty close to E and still wasn't coming on. i'll have to test it out more i guess.
Old 08-15-11, 05:15 PM
andrewa
andrewa's Avatar
Does that mean that you need to leave a gallon of fuel in the tank for it to remain cool? In other words, it's still bad if you don't "run out" of fuel but come close to it.
Old 08-15-11, 08:11 PM
midcow3
midcow3's Avatar
A little over compensation Eh! Running out of gas must have left an indelible mark ... because 1/2 tank is nowhere close to EMPTY I guess you go to the gas station often in your CT
Old 08-16-11, 04:08 AM
Bob259
Bob259's Avatar
I would guess that would depend on tank design and location by the auto manufactures.
Old 08-17-11, 02:56 PM
dkidwell
dkidwell's Avatar
Not really, about every 8-10 days. Retirement is great.
Old 08-18-11, 04:40 AM
jimmyc13
jimmyc13's Avatar
Ha ha ha!
Quick Reply: Poll: What is the most gallons you've put in the tank
