CT 200h Model (2011-2017)
Ct200h - Evaporator plug exact location ?
Old 07-21-16, 10:04 AM
kulkarnipb
kulkarnipb's Avatar
Default Ct200h - Evaporator plug exact location ?
I'm having bad mold smell from my 2011 ct200h AC. I'm looking forward to use the AC foam refresher kit but I'm unable to locate the evaporator plug.
Some says behind right front tire (when tire turned left), while some points to under engine cover. Can someone please confirm evaporator plug exact location ?
Thanks in advance.
Old 07-23-16, 09:43 PM
kulkarnipb
kulkarnipb's Avatar
Never-mind, I figured out the evaporator drain plug location and alternative way to clean it . I cleaned the drain line, which was causing the smell. Now - after cleaning - there is no smell at all. I created video too for reference .....
Old 07-24-16, 02:05 PM
nacke
nacke's Avatar
Great DIY video, thanks for the effort!
Old 07-26-16, 08:52 AM
SteveMason
SteveMason's Avatar
Thanks for the video! I will use this tutorial as mine isn't too fresh smelling. When it is on it is okay, but after I turn it off it smells for a while.
Old 07-26-16, 12:03 PM
Clutchless
Clutchless's Avatar
Received 1,092 Likes on 932 Posts
Great video. Be sure to remove your cabin air filter before cleaning the evaporator. It will soak up the cleaning fluid and especially the Lysol when it is sprayed in the vents..
Brabusx2
07-08-17 11:56 PM
Erikjohn
GX - 2nd Gen (2010-2023)
04-02-15 12:05 PM
JML311
07-20-13 05:52 PM
neurocity
06-24-09 04:01 PM
Quick Reply: Ct200h - Evaporator plug exact location ?
