CT 200h Model (2011-2017)
Oil change type
Old 06-22-16, 11:57 PM
Lightmania
Lightmania's Avatar
Default Oil change type
Hello,
I bought a lexus ct200h 2011 few months age i changed oil in lexus in my country they changed it to 10w-40 instead of 0-20 i asked why they said it because of the weather they changed the standards so i thinking of changing it to 0w-20 toyota
What do you think any thoughts?
Thank you
Old 06-23-16, 03:29 AM
Lightmania
Lightmania's Avatar
Any help please ?
I want to know if 10w-40 (Lexus) bad for the car or not ?
Thanks
Old 06-23-16, 05:02 AM
StillLine
StillLine's Avatar
I don't know if it will damage the engine, but I would expect your fuel economy will suffer. According to the owner's manual, the engine was designed for 0w-20 for all climates. I'd also be concerned with excessive engine wear at cold start up. If this is a Lexus dealer telling your this, I'd ask to see the documentation from Lexus corporate regarding this supposed change in standards.
Old 06-23-16, 08:35 AM
irondonkey
irondonkey's Avatar
change it out to 0w-20.
Old 06-23-16, 10:52 AM
Lightmania
Lightmania's Avatar
I will change it immediately and my fuel is a bit high compared to what i read about it.
My consumption per full tank is 500 km
Thank you
Old 06-23-16, 04:32 PM
roadfrog
roadfrog's Avatar
TGMO 0W20 is the oil to use. It also has very high moly count, which is engineered to Lexus vehicles. It's a VERY high quality oil. One of the best.
Old 06-25-16, 02:13 AM
Lightmania
Lightmania's Avatar
Is this the oil i can use for my car?<br/><br/>If i can have aome fast replay please <br/><br/>Thank you<br ><br >
Old 06-25-16, 02:15 AM
Lightmania
Lightmania's Avatar
I would like to know if this is the oil for my lexus ct200h car
If someone can confirm please
Old 06-25-16, 05:01 AM
yeldogt
yeldogt's Avatar
That container is the proper Toyota oil ... most here on the forum are from the USA ... Toyota's container is different in the USA. In the USA only 0-20 is approved for extended oil changes.
You must not have the owners manual that came with the car in Jordan? It should be easy to find or download one? The manual will give you any other possible oils.
Old 06-25-16, 05:45 AM
Lightmania
Lightmania's Avatar
The car is not from jordan but i live in jordan
I think its germany or nethetlands
Thank you
Old 06-25-16, 07:27 AM
yeldogt
yeldogt's Avatar
You should be able to find out what Toyota recommends ---
Old 06-26-16, 03:42 PM
Trexus
Trexus's Avatar
0W-20 is the correct oil. You can also use 5W-20. You have the correct oil with the picture of the Toyota oil SN 0W-20.
The 10W-40 oil is way too thick. Good job on changing the oil back to 0W-20.
Old 06-26-16, 04:34 PM
steelers6
steelers6's Avatar
WELL THERE YOU HAVE IT,thats all i needed to see...
Old 06-26-16, 09:10 PM
Trexus
Trexus's Avatar
I change the oil and oil filter on my 2011 CT every 5,000 miles and I use Eneos Sustina 0W-20 oil and a Toyota OEM filter part number 04152-YZZA6.
Old 06-27-16, 04:06 AM
steelers6
steelers6's Avatar
Eneos Sustina,who makes that type of oil,never heard of it???
Quick Reply: Oil change type
