Lowering my CT
Lowering my CT
I have a set of FSport springs for my CT, is it a do it your self project that I can do or should I have a professional do it?
Thanks
Thanks
I'm somewhat mechanically inclined but if you don't have the proper tools and equipment then I would have a professional do the job...you'll save time and it's safer. Working with springs one can get seriously hurt if you do not know what you're doing...
With struts you need a spring compressor and the knowledge to safely use it as serious injury can result if a spring gets loose from under tension. You also need an alignment after spring installation.
tnbigdawg
Suspension and Brakes
17
01-26-08 01:59 PM
