CT 200h Model (2011-2017)
2014 Road Noise Improvements?
Old 02-16-14, 11:25 PM
CrysDark
CrysDark's Avatar
Default 2014 Road Noise Improvements?
With the 2014s hitting the lots do we now know what some of these 100+ improvements to the cabin to combat road noise are? I would love to see if its possible to retro-fit my 2012 as road noise is my biggest complaint right now.
Old 02-24-14, 02:14 PM
Clutchless
Clutchless's Avatar
Received 1,097 Likes on 936 Posts
Some will be an increase in the amount of sound deadening materials in body panels such as doors, rear hatch, wheel wells, floor. Increase in padding under carpet, and by front fire wall. Improved body stiffness. Improved suspension isolation, improved engine mounts etc etc. I heard the suspension tuning gets some revisions too.
Old 02-25-14, 02:33 PM
pbm317
pbm317's Avatar
Probably can't retrofit much. If it's that bad in your car maybe you could add some dynamat to your car.
Old 02-26-14, 12:43 PM
Clutchless
Clutchless's Avatar
That is what I did to mine. The biggest improvement came from using paint on deadener such as Spraydead on the front wheel well section near the door. This is the part not covered with a liner. 4 coats and the engine noise was much less. I also did Raamat (similar to Dynamat but less expensive and just as good) on the rear hatch area including a lot in the spare tire hole, inside the rear hatch and somewhat up the sides. It did not make that much difference. http://www.spraydead.com/
Found this information on a UK web site review of the 2014:
To improve body rigidity, Lexus has broken out the structural adhesive and found space for 20 additional spot welds around the tailgate, allowing it to adjust the spring rates on the CT200h’s notoriously tough suspension. It has also introduced 94 separate measures to combat the car’s thoroughly un-Lexus like NVH problems, including improved sound deadening behind the dash and in the rear arches.
Sanss90
01-07-19 06:52 PM
Boston35
Suspension and Brakes
11-07-12 11:02 AM
peteran85
07-26-11 05:15 PM
ILOVEGIRLS
03-14-06 06:22 PM
Quick Reply: 2014 Road Noise Improvements?
