CT 200h Model (2011-2017)
hey guys, can you help real quick? wheel fitment question
Old 12-03-13, 10:30 AM
tommigsr
tommigsr's Avatar
Default hey guys, can you help real quick? wheel fitment question
will these fit?
VarrsToen ES2 (2.2.1) 18x9.5 +34 5x100
I've seen posts on the lowest offset thread where peepz were running 18 x 9.5 but +38, these are +34...
let me know!
Old 12-03-13, 03:32 PM
nabbun
nabbun's Avatar
Are you lowered? If so, by how much?
Old 12-03-13, 08:59 PM
tommigsr
tommigsr's Avatar
not lowered yet, but will be getting coilovers =]
Old 12-04-13, 01:23 PM
nabbun
nabbun's Avatar
The new wheels might stick out a bit.
Old 12-04-13, 01:40 PM
OKSTANCE
OKSTANCE's Avatar
if wanting aggressive fitment on coilovers you should get away with it assuming you are able to
run some negative camber, stretch a little tire, and show a little minimal love to the fenders
Old 12-04-13, 02:25 PM
bojeda123
bojeda123's Avatar
Sorry just need quick help. Anyone know if 2006 Mazda rx8 wheels would fit on my 2001 lexus is 300?
Old 12-04-13, 03:39 PM
nabbun
nabbun's Avatar
do you have wheel size and offset?
Old 12-04-13, 08:03 PM
Doublade
Doublade's Avatar
You should be able to clear fine, this was me when I had 18x8.5 +35 all around +20mm spacer in the rear
Attached Thumbnails hey guys, can you help real quick? wheel fitment question-image-1414062851.jpg
Doublade
Doublade's Avatar
And just found this one too, which resemble your fitment more. This was a 18x9.5 +38 setup with+20mm spacer in the rear as well
Attached Thumbnails hey guys, can you help real quick? wheel fitment question-image-2490399448.jpg
Old 12-05-13, 01:06 AM
Tennis100
Tennis100's Avatar
Damn Doublade, you make me hate my CT.
Old 12-05-13, 06:01 AM
OKSTANCE
OKSTANCE's Avatar
check out thomas phans wheels specs on his work's..i wana say they are somewhat close to those specs
Old 12-05-13, 11:19 AM
Doublade
Doublade's Avatar
Oh sir I'm sure yours is a lot better than mine!
Old 12-05-13, 01:25 PM
nabbun
nabbun's Avatar
I just hate how hard it is to find wheels you want in the aggressive offsets many of us want . . .
Old 12-06-13, 09:03 AM
GetUrWheel
Former Sponsor
GetUrWheel's Avatar
Front's will be aggressive and will require some camber bolts. I think 225's will work, but 235's may require a slight roll/pull on the fenders.
Rears will be fine, and can probably use a 5-10mm spacer depending on how aggressive of tires you end up going with, and also if you plan on rolling the rear fenders.
8UR911
Wheels, Tires & Brakes Forum
04-07-10 12:18 PM
Choiza
IS - 1st Gen (2001-2005)
11-19-09 02:20 PM
mikez
02-12-09 04:57 AM
Quick Reply: hey guys, can you help real quick? wheel fitment question
