CT 200h Model (2011-2017)
LED Headlight Upgrade
Old 10-23-13, 05:42 PM
lldsandsll
lldsandsll's Avatar
Default LED Headlight Upgrade
Hey guys, new member, and also total newb with respect to LED headlights.
I just installed a 6000K HID kit and had to get relays to get them to power on. I'm pleased with the upgrade but I was poking around online and found this:
http://store.ijdmtoy.com/High-Power-...headlights.htm
Anyone have any feedback on that kit? How does it compare? Is that the only part needed? Etc.
I'd consider switching to an LED kit.
Old 10-24-13, 08:58 AM
nabbun
nabbun's Avatar
Your HID kit is most likely putting out more light than that LED kit. That LED kit only puts out about 1600 lumens.
Old 10-24-13, 12:10 PM
lldsandsll
lldsandsll's Avatar
thanks. what is the lumen output of the stock LED kit?
Old 10-24-13, 02:13 PM
whlkev
whlkev's Avatar
really no point to go LED, they are less bright, only thing cool about them is the headlight if they come stock
think i read it somewhere on this forum that LED was rated around 2500 lumens and the HID is around 3200
HID is the way to go
Old 10-24-13, 05:49 PM
nabbun
nabbun's Avatar
Stock halogen bulbs range from 1200-1400 lumens. Stock LED is in the low 2,000 range. Stock HID is 3200. Aftermarket HID kits range in lumen output depending on their quality. I highly recommend the kits from Morimoto such as their 3five kits. We also have vendors who sell quality kits as well.
Old 10-25-13, 01:56 AM
jennypenny
jennypenny's Avatar
but the LED headlights has double bulbs, its is just as bright as the LEDs.
i read somewhere, need to look for that link. yes. per bulb basis, HID is more powerful. hence LED bulb setup typically has double bulbs to increase the Lumens.
Old 10-25-13, 06:13 AM
lldsandsll
lldsandsll's Avatar
i've been seeing double LED on all kits, but overall, the output is apparently less.
Old 10-25-13, 02:22 PM
nabbun
nabbun's Avatar
The biggest factor limiting the performance of LED lighting is heat. LEDs are very efficient however, they put off a ship ton of heat. Heatsink technology is huge. If they can figure out a cost effective way to manage the heat, LED lighting will become better and replace HID.
actright
ES - 6th Gen (2013-2018)
02-07-19 06:25 PM
TechNut
45
05-16-17 05:26 AM
eclipsegst
Lighting
03-24-16 08:24 PM
LexISguy
12-09-10 08:52 AM
LexISguy
IS F (2008-2014)
11-19-10 09:08 AM
Quick Reply: LED Headlight Upgrade
