Power door locks problem - needs a locksmith
I have my Lexus CT 200h and i have power door lock problems with my car. he power door locks dont work. The front passenger and the rear seat doors will not unlock. I have checked the fuse and it is ok. so i need a help of locksmith and if anyone knows about good quality locksmith kindly inform me from here.
I think from factory when you unlock the car only the driver door unlocks. You have to ask the dealer if you want all four doors to unlock when you unlock the driver door.
press the unlock button once for driver door unlock and puts it twice for all doors. you can change this setting by pressing mode on the odo and go into settings. look in the manual for an elaborate definition of each. I set mine so if hand in door all does unlock and same with key
Posted from ClubLexus.com App for Android
Push and hold the unlock and lock buttons on the Smart Key... keep them both depressed until you hear an audio confirmation beep. AND the info display (lower right on dash) will show an image of the setting that is now active.
locksmith??!?
as others said, it comes STANDARD for only the DRIVERS door to UNLOCK..
if you have NAVIGATION, you can change this by going to: SETUP>VEHICLE>DOOR LOCK SETTINGS
otherwise, NO NEED TO PANIC! go to your nearest LEXUS dealer for assistance!
Do you mean that you are trying to unlock all doors with your remote as you walk up to the car? If so, click the "unlock" button on the remote twice quickly. That unlocks all doors and the hatch.
jpzy3rxh
Hybrid Technology
09-15-09 05:26 PM
carnal_c30
03-26-06 02:45 PM
EmeraldLexuSC3
SC- 1st Gen (1992-2000)
07-20-02 09:05 PM
