Go Back   Club Lexus Forums > Vendor Marketplace and Classifieds > Club Lexus Vendor Marketplace
Sign in using an external account
Register Forgot Password?
StopTech Ultra-High Performance Big Brake Kit for Lexus IS IS250 IS350
Thread Tools Search this Thread Display Modes
Old 06-17-14, 09:30 AM   #1
Need4Speed
Sponsor
Trader Score: (0)
Need4Speed's Avatar
https://www.facebook.com/Need4SpeedMotors https://twitter.com/N4SMotorsports http://instagram.com/need4speedmotorsports#
Default StopTech Ultra-High Performance Big Brake Kit for Lexus IS IS250 IS350
Need 4 Speed Motorsports | StopTech Aftermarket Big Brake Kit | Lexus IS IS250 IS350 F-Sport & Hybrid
StopTech®, the ultra-high performance brand from Centric Parts®,
offers a full range of high performance aftermarket brake systems and components for thousands of vehicle applications.
Every StopTech component and kit is custom engineered for a specific vehicle.
Using a kit designed for another vehicle will likely reduce performance.
From the patented StopTech® AeroRotors and removable-bridge,
differential-bore StopTech calipers to race components, big brake kits,
sport rotors, pads, lines and fluid - StopTech has something for every performance need..
PM or Email For Pricing!
Jose@N4SM.com
(888) 714-7467 and ask for Jose for pricing!
StopTech Ultra High Perfromance Big Brake Kit
-Ultimate brake upgrades for track or street
-Larger rotors with patented cooling technology
-Stiffest calipers for reduced compliance
-Stainless Steel Lines for better pedal feel
-All brackets and hardware to complete the job
-Custom engineered for each application
StopTech Trophy Ultra High Perfromance Big Brake Kit
-Patented StopTech® AeroRotors® for optimized airflow
-Patented, billet 7075 aluminum AeroHats® to further increase airflow
-Forged StopTech® STR calipers with patented bolt-in bridge for ultimate stiffness
-StopTech® stainless steel brake lines
-Race engineered caliper brackets
-Hard-anodized finish on calipers and hats that resists fading and discoloration
StopTech Calipers
-Fully forged and stiff for firmer brake pedal feel
-Carefully engineered, 2-piece design reduces flex. The carbon steel caliper bolts running through both halves multiply strength by 3-fold.
-Patented, removable center bridge further resists yaw
-Carefully selected piston sizes for precise torque output
StopTech Brackets & Hardware
-Studs provide strength and durability rather than the more common bolts
-Fully machined aluminum or steel for precision and strength
-Application specific for precise and proper fitment
-All necessary hardware for easy bolt-on installation
StopTech Stainless Steel Brake Lines
-Stainless steel braiding for lower compliance and extra protection
-A variety of fittings for hundreds of applications
-All necessary brackets and fasteners to finish the job
-Provides quicker response
-Firmer pedal feel
-Better brake modulation
StopTech Sport Rotors
StopTech's patented AeroRotors® are 2-piece replacement rotors featuring a billet aluminum AeroHat® and AeroRotor® friction ring.
These rotors feature a patented AeroVane® optimal cooling vane design to improve rotor airflow, cooling and heat capacity.
This improved directional design minimizes turbulence and flows up to 61% more air than any rotor tested. Better airflow means better cooling and less fade.
The 2-piece design of the StopTech® AeroRotors® allows for independent expansion of the rotor and hat without coning.
Additionally, AeroRotor® assemblies are up to 8 pounds lighter than stock rotors and are available either drilled or slotted.
An optional anti-corrosion gold zinc coating benefits customers who live in cold climates, where snow and road salt are commonly encountered.
Zinc coating also benefits customers who prefer no visible surface rust on the vanes and outer circumference of rotors.
StopTech® AeroRotors® are 100% made in the USA, with both casting and machining taking place in California.
-Larger than factory brake rotor for better overall brake performance
-Unique slotting and/or cross-drilling to aid heat and brake dust dispersal
-Black e-coating for added protection from corrosion
-Factory cooling vane design or directional vanes for improved cooling
-Available with an optional Cryogenic treatment for added durability
StopTech® Sport Rotors are direct replacement discs for your factory brake system and stock calipers.
They offer improved cooling as well as other advantages the competition doesn't offer.
Slotting and/or cross-drilling helps wipe away the debris that forms between the pad and the disc, adds more bite, and can help
the rear brakes to match the aesthetics of a front big brake kit.
The rotor finish helps prevent glazing of the pads and improves wet and dry braking performance.
Additionally, StopTech® Sport Rotors feature a durable black e-coating on the non-swept areas of the rotor to prevent corrosion.
All StopTech® Sport Rotors are also available cryogenically treated to better align the molecular structure of the disc for enhanced durability and longer life.
When so treated, they are known as StopTech Cryo® rotors.
StopTech Premium Rotors
Centric® Premium Rotors are blank, 1-piece, direct replacement discs for your factory brake system.
They feature Original Equipment specifications and production processes.
Centric® rotors are manufactured to meet QS and ISO Quality System Standards.
Like many StopTech rotors, Centric® Premium Rotors offer several key advantages over stock rotors:
-E-Coating - Electrocoating finish that provides long lasting corrosion protection.
-Double Disc Ground - Double disc grinding eliminates run out and allows more effective pad-rotor break in.
-Machined Finishes - 100% fully machined finishes provide better rotor balance and a more finished look.
-Split Castings - Center-split core castings provide proper heat transfer and thermal efficiency.
-Mill Balancing - Mill balanced to reduce feedback associated with rotor vibration.
How to Place Your Order
Phone Domestic: Toll-Free 1-888 714-7467
Phone International: 1-818 547-5474
E-mail: Jose@N4SM.com
Website: www.N4SM.com
Please do not hesitate to contact us should you have any questions.
We have over 70 years of combined experience and 13 years of hands on experience in the automotive industry.
Payment:
Credit/Debit Cards: Visa, Mastercard, Discover, and American Express.
We can process your payment right over the phone and online on our website.
Paypal: Visa, Mastercard, Discover, and American Express.
Bank Wire Transfer: We accept direct wire transfers to make it easy for you place order.
Please contact us so that we can email you more information & instructions.
Shipping:
All orders are shipped via FedEx Domestic and International.
If you are located in Hawaii, Alaska, or international, please e-mail, pm, or call us for the most competitive rates.
Hours of Operation:
Monday through Friday from 8:00 a.m. to 6:00 p.m. PST
Saturday from 9:00 a.m. to 3:00 p.m. Pacific PST
Our website is open 24 hours a day / 365 days a year!
Contact Information:
Phone: 1-888-714-7476 Toll-Free
Email: Jose@N4SM.com
If you have any questions or concerns, do not hesitate to contact us. We are here to help you!
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
Need4Speed is offline   Reply With Quote
Old 06-17-14, 10:26 AM   #2
RastaRacer
Trader Score: (5)
RastaRacer's Avatar
That so sick, cant wait to see these bad boys on a 3IS.
__________________
2015 RCF - Ultrasonic Blue / Circuit Red
Vossen Wheels x RSR Suspension
RastaRacer is offline   Reply With Quote
Old 06-17-14, 10:34 AM   #3
zarraz
Trader Score: (0)
how much shipped to Canada postal code n3c3w5
zarraz is offline   Reply With Quote
Old 06-17-14, 12:20 PM   #4
ohiois350
Trader Score: (11)
How much for both kits and the sport drill and slot rotors for 07 IS350?
__________________
07 IS350 Obsidian/2012 F-Sport front end conversion&2010 Tail lights upgrade/GFX side&rear/s2k tips/5000K Phillip D4s&4300k Phillip H11 rebased bulbs with Denso ballasts fog/White doors sill/6000K V-LEDS interior&parking lights/6000K V-LEDs back up lights/LED turn signal mirrors/LS door lock&LED/ F-sport complete suspension set up/ 20" Vossen VSF 1/hard wire 9500IX for speeding
14" GX luxury white with ecru
ohiois350 is offline   Reply With Quote
Old 06-17-14, 05:00 PM   #5
Need4Speed
Sponsor
Trader Score: (0)
Need4Speed's Avatar
Quote:
Quote:
PMs have been sent
Old 06-23-14, 08:34 AM   #6
LIG134
Trader Score: (0)
How much for BBK with cross drilled front and rear for '06 IS350?
__________________
2006 IS350 CW | Lux Pkg | Nav | ML | 6000k
1995 MX-5 Blk | R-Pkg | KYB AGX | FM Springs | Greddy Tower Brace | RB Sways | 17"
LIG134 is offline   Reply With Quote
Old 06-23-14, 12:40 PM   #7
Need4Speed
Sponsor
Trader Score: (0)
Need4Speed's Avatar
Quote:
PM Sent !!!
Old 06-23-14, 07:11 PM   #8
Kaze524
Trader Score: (0)
How much for the StopTech Ultra High Performance BBK with drilled front and rear AWD 08 IS250?
Kaze524 is offline   Reply With Quote
Old 06-24-14, 11:56 AM   #9
Need4Speed
Sponsor
Trader Score: (0)
Need4Speed's Avatar
Quote:
pm sent
Old 07-14-14, 11:29 AM   #10
Need4Speed
Sponsor
Trader Score: (0)
Need4Speed's Avatar
We will be celebrating Germany's victory all week long with amazing deals
Pm for details
Old 07-14-14, 11:45 AM   #11
zarraz
Trader Score: (0)
hi sorry but did not get your pm, how much for the stoptech bbk kit front and rear, for the 2014 IS250 Awd, shipped to Ontario Canada n3c3w5, thanks
Old 07-14-14, 04:19 PM   #12
Need4Speed
Sponsor
Trader Score: (0)
Need4Speed's Avatar
congratulations on the front & rear system
Old 08-08-14, 11:38 AM   #13
Need4Speed
Sponsor
Trader Score: (0)
Need4Speed's Avatar
Happy Friday Guys.
Old 12-11-14, 04:47 PM   #14
Need4Speed
Sponsor
Trader Score: (0)
Need4Speed's Avatar
Happy Thursday everyone!
Lets get down to business and install some serious braking power.
Pm us for more info.
Old 12-11-14, 10:59 PM   #15
geero
Trader Score: (1)
can u pm me price for 2015 is350 fsport
geero is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Stoptech brake rotors, pads and SS brake lines b2designs Club Lexus Vendor Marketplace 188 04-19-15 11:23 AM
StopTech Ultra-High Performance Big Brake Kit for Lexus IS ISF ES GS LS Need4Speed Club Lexus Vendor Marketplace 2 07-29-14 11:44 AM
TX FS: BBK Brembo GT 355mm 4 Piston Black JeffTsai SC400 / 300 Classifieds 1 06-01-14 02:30 PM
** Assaultech.com Brake Deals - BBKs Rotors Pads Lines & More ** Dan@Assaultech Club Lexus Vendor Marketplace 17 12-07-12 09:27 AM
****// Assaultech.com CL Brake Specials - Rotors, Pads & SS Lines \\**** Dan@Assaultech Club Lexus Vendor Marketplace 74 10-26-12 11:19 AM
Tags
big, brakes, kit, lexus, stoptech
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
