Get Maximum Stopping Power with Hawk Brake Pads, SS lines and Brembo Fluid!
Hawk Performance Brake Pads:
Performance Ceramic
Ultimate stopping power in an ultra-low dust, low noise ceramic compound!
Hawk Performance has introduced a premium, high performance, ultra-low dust, low noise compound called Performance Ceramic.
Performance Ceramic is engineered to reduce brake NVH (Noise, Vibration and Harshness), creating a quieter performing brake pad. Furthermore, the ceramic brake pad formula has a linear friction profile that allows your ABS brake system to work more effectively. With Performance Ceramic you can expect reduced brake pad wear, lower dust output levels and a rotor-friendly brake pad.
Performance Ceramic – quiet, clean & fast stopping!
Key Features:
Increased stopping power
Increased rotor life
Extended pad life
Ultra-low dust
Extremely quiet
Stable friction output
HPS Pads:
HPS - High Performance Street disc brake pads are world renowned for increasing stopping power on your street legal vehicle. Increasing the performance of your vehicles braking system is easy when you choose Hawk Performance’s HPS braking compound. This unique Ferro-Carbon formula was developed for street performance using the safety and quality of Aerospace and Motorsports severe-duty friction technology.
The High Performance Street compound offers a higher coefficient of friction over stock brake pads and can provide you 20-40% more stopping power and higher resistance to brake fade than most standard replacement pads. Less fade means you’ll have a highly durable brake pad with less brake dust..
HPS Ferro-Compound Features:
High friction/torque hot or cold
Gentle on rotors
Extended pad life
Low dust
Virtually noise-free
Not recommended for use on lapping days or for open track use. Great for daily driving or a quick auto-x
HP Plus Pads
Hawk Performance’s HP Plus brake pad compound is ideal for Autocross and Track Day drivers looking for a high performance race compound that can take the heat of the track and get you home safely without having to change the pads.
HP Plus utilizes a unique Ferro-Carbon, high-tech friction material that was developed and manufactured for sport driving in autocross, Solo II and “track day” applications. The Ferro-Carbon formulation offers lower wear rates and higher torque values than other competitive materials.
Extremely high coefficient of friction makes HP Plus the perfect upgrade over stock for high performance streetcars used in autocross competition or that experience repetitive, heavy braking.
Key Features:
Extremely High Friction Output
Fade Resistant
Worthy for Autocross & Club Racing Events
Warning! Due to the dramatic friction levels produced by this product to achieve "race-level" braking, rotor wear, noise, dust, and pad life may be affected.
We also sell Rotors, High Performance Brake Fluid, and Stainless Steel brake lines!
With a high performance pad and rotor combo you will need a high performance brake fluid to keep up without boiling!
Brembo SPORT.EVO 500++ is a premium specification Motor Vehicle Brake and Clutch Fluid which conforms to and exceeds the current international specifications. Typical dry boiling point 271 Deg C., typical wet boiling point 169 Deg.C.
Squishy pedal feel? Your stock rubber lines will expand when under pressure, leading to a squishy pedal and poor brake response. Fix it with Russell stainless steel brake lines:
Go here for our huge rotor sale:
https://www.clublexus.com/forums/clu...powerslot.html
