New Product RR Racing Ultimate Steering Response System for 2IS
Sponsor
Some of you may have already read about the great reviews our Ultimate Steering Response System (USRS) is getting on the ISF forums, but this upgrade will also transform the steering response and handling of your 2IS as well.
One thing that is important to emphasize is that this is not just a replacement bushing. We have designed a bushing/housing system that eliminates all the thrust movement of the standard or upgraded bushings.
By eliminating excessive movement of the soft stock lower control arm bushing, we dramatically improved steering response and feel during hard cornering, without the excessive vibration and harshness associated with race-only hard spherical bearings. As illustrated in our image gallery, the OEM suspension control arms, under braking and cornering, actually move with respect to the chassis. This results in increased understeer, non-linear steering response, and reduced stability under hard braking conditions, and in many cases excessive inner tire wear, a well known problem on many Lexus models. We have designed our USRS to significantly reduce all dynamic toe changes and lateral deflections!
Please watch the video below for a detailed overview of USRS and on-car comparison between USRS and the Lexus OEM bushing.
Summary of Features:
•Our bushing virtually eliminates unwanted suspension movement, that lead to changes in toe, caster, and camber while turning and braking.
•Our redesigned housing increases static caster by 0.3-0.5 degrees. Increased caster improves steering feel and camber gain when cornering.
•Comes as a complete and assembled bushing & housing assembly - no costly labor and hassle in pressing out old OEM bushings.
•Redesigned 6061-T6 lower control arm housing designed to be stronger than OEM to withstand increased thrust loads.
•Extremely tough 95A durometer polyurethane bushing -- backed by our lifetime guarantee!
•Polyurethane bushing features fully fluted design on shaft and thrust side for enhanced lubrication. Also features end seal to keep dirt out.
•Track tested and track proven on our shop IS-F!
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
SJP23 (10-29-20)
Sponsor
check out this video comparing the USRS to the OEM bushing.
Please note:
(1) ZERO lateral deflection during cornering
(2) ZERO rearward movement of the lower control arm during braking
(3) MINIMAL lateral movement of the bushing during braking.
Please note:
__________________
Your #1 Lexus Vendor
This improved my ISF's steering and toe wear a lot.. I know you 2gen IS people have these issues too. Hit me up through PM so I can get you hooked up with Rafi!
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
Sponsor
A big thank you to Kurt from EatSleepDriveTV for the install and review video of our USRS upgrade!
__________________
SJP23 (10-23-20)
Sponsor
Another batch assembled and ready to ship! Who is looking for a set of either Street, R&T or Race USRS?
__________________
RRRacing
CL Vendor Products for 3IS
23
08-28-20 08:29 AM
RRRacing
CL Vendor Products for RC-F
11-07-15 04:44 AM
RRRacing
11-02-15 04:28 AM
RRRacing
CL Vendor Products for IS-F
08-31-15 01:10 PM
RRRacing
07-01-15 01:17 PM
