disassembling a car. When is it ok to leave the battery plugged in?
Old 02-05-17, 06:19 PM
pman6
pman6's Avatar
Default disassembling a car. When is it ok to leave the battery plugged in?
I want to remove the front passenger seat. It's a power seat and probably has a power connector or two underneath.
Repair manual always says to disconnect one battery terminal when playing with any powered car component. But what will really happen if I leave the battery plugged and then unplug the power seat?
I just don't want reprogram everything after disconnecting the battery, so I'd rather leave the battery always connected if there is no real impact.
pman6 is offline
Old 02-05-17, 06:37 PM
Och
Och's Avatar
You'll be fine.
Och is offline
Old 02-05-17, 06:39 PM
mmarshall's Avatar
Does the power-seat circuit have a fuse in the fuse-panel that you can pull? If so, that would cut off power to the seat-circuits without having to disconnect the battery terminal.
Moderators: I'd suggest moving this question to the Maintenance Forum.
mmarshall is offline
Old 02-05-17, 10:02 PM
Aron9000
Aron9000's Avatar
I think you'll be okay just unplugging the connectors. If it were a German car, I'd unplug the battery, because the electrical systems in those cars are way more(needlessly IMO) complicated.
Aron9000 is offline
Old 02-05-17, 10:25 PM
thoiboi
thoiboi's Avatar
Good call on just removing the fuse! It's one of those better safe than sorry situations. It may be fine but some people have fried MICU/ circuit boards by doing something as silly as replace a courtesy light bulb.
thoiboi is offline
Old 02-07-17, 06:53 AM
CleanSC
CleanSC's Avatar
It's only a worry if the seat has an airbag in it.
If it doesn't, don't bother. Those circuits are just seatbelt sensors and seat motors.
CleanSC is offline
Old 02-07-17, 12:44 PM
LOWFAST
LOWFAST's Avatar
^This, be cautious of the airbags, better safe than sorry. If they go off you have a huge replacement cost, and high probability of serious injury.
LOWFAST is offline
jednav
02-06-18 07:35 PM
Akachan LS
Maintenance
10-29-10 03:46 PM
Todd
RX - 1st Gen (1999-2003)
14
10-27-04 12:49 PM
jobindj
Maintenance
12-02-02 04:28 PM
Quick Reply: disassembling a car. When is it ok to leave the battery plugged in?
