Free engine replacement for 2006-2009 Honda Civics
Old 03-27-14, 06:33 AM
Joeb427
Joeb427's Avatar
Default Free engine replacement for 2006-2009 Honda Civics
Traded in my son's '08 with 106K miles with no leak.I guess the problem isn't in all the engines.
Published March 27, 2014
Do you own a 2006 to 2009 Honda Civic with a coolant leak? You could be in luck. Honda is offering a new engine block or completely new engine, free, to owners of 2006 through 2008 and some early 2009 Civics that have developed a coolant leak coming from the engine block. The free service applies to all Civics except the Hybrid and the Civic Si, and it effectively extends the original warranty to eight years, regardless of mileage.
Why this matters: The leak can allow coolant to drain away, leading to overheating or a total engine failure. Honda alerted known owners back in 2010, but a lot of people probably didn’t get the message, especially second or third owners of the cars.
The program: For Civics that have developed one or more cracks in the engine block and started leaking coolant, Honda dealers will replace the engine block, or the entire engine if the head has warped too, at no charge. The offer applies to affected Civics that have been on the road eight years or less, regardless of mileage.
What to do: If your Civic is seeping coolant from the engine (not the radiator or hoses), or overheating, take it to a Honda dealer and mention technical service bulletin 10-048. If you already had the engine replaced at your own expense, you can apply for a refund from Honda Customer Service (800-999-1009) as long as the work was done at a Honda dealer or if you can prove that the repair was done with genuine Honda parts.
—Gordon Hard
Joeb427 is offline
Old 03-27-14, 07:26 AM
PhilipMSPT
Cycle Savant
PhilipMSPT's Avatar
Is there a service bulletin we can print out?
PhilipMSPT is offline
Old 03-27-14, 07:31 AM
Harbinger
Harbinger's Avatar
Soooo... It would be feasible that one could actively seach for an 06 R18 equipped civic coupe with a blown head gasket/warped head/cracked block/pissed off owner who is in the dark and swap in say a K23, making sure that you purchased all OEM Honda parts & be reimbursed for creating the civic that Honda should have built in the 1st place?? Sounds win-win
Harbinger is offline
Old 03-27-14, 07:32 AM
Joeb427
Joeb427's Avatar
All I've seen is that article.
http://www.foxnews.com/leisure/2014/...ntcmp=features
Joeb427 is offline
Old 03-27-14, 07:39 AM
PhilipMSPT
Cycle Savant
PhilipMSPT's Avatar
Thanks buddy!!
Old 03-27-14, 09:13 AM
Joeb427
Joeb427's Avatar
Same article in Consumer Reports.
http://www.consumerreports.org/cro/n...vics/index.htm
Joeb427 is offline
SteveMason
CT 200h Model (2011-2017)
07-09-19 12:47 AM
TMaxxTim
Performance & Maintenance
39
05-04-06 09:43 PM
ozlx470
10-28-04 12:53 PM
Quick Reply: Free engine replacement for 2006-2009 Honda Civics
