Koenigsegg One:1 Hypercar
Old 10-09-13, 02:24 AM
Blackraven
Blackraven's Avatar
Meh. Just buy one of these:
Hehe
Unfortunately, those are not street-legal
Blackraven is offline
Old 10-09-13, 10:09 AM
92 SC400
92 SC400's Avatar
Is it going to look like a Power Wheels car? If that's the case, it'll also be fully electric! haha
92 SC400 is offline
Old 02-28-14, 08:32 AM
Seize
Loves Snickerdoodles!
Seize's Avatar
Koenigsegg One:1
This is the one everyone has been waiting for, the Koenigsegg One:1, destined for the Geneva Motor Show 2014, has now been made official! Koenigsegg released official details of the world’s first mega car this morning. The press release is 40 pages long and probably took as long as the car to develop so we’re giving you a concise run-down of the salient facts!
To start with, the Swedish company have set out their success in intricate detail. With 5 Guiness World Records to their name, 5 generations of the Koenigsegg philosophy and 100 happy customers, Koenigsegg are taking their platform to a new level with the One:1.
The design incorporates a unique set aerodynamic updates. These include the use of track optimized aero winglets on the front bumper, extended venturi tunnels and side splitters, a Le-Mans inspired active wing configuration at the rear and an optimized active undertrim air management. Large air vents for improve cooling to the engine and a roof air scoop helps to keep the car glued to the ground.
The Koenigsegg One:1 with all its new parts features a drag coefficient of 0.45-0.50 depending on the adaptable rear wings. The total downforce produced at 260 km/h is equal to 610 kg whilst at 440km/h, the One:1 develops 830 kg of pressure. It features a flat underside and venturi tunnels at front and rear of the chassis as well as active aero at the front and rear underside to achieve this. Compared to the Agera R, the One:1 produces almost twice as much downforce at 250 km/h. The One:1 pulls 2G in the corners on road legal tyres.
So, to the engine. Koenigsegg retains its own design Koenigsegg aluminium 5,0 litre V8 unit with, 4 valves per cylinder, double overhead camshafts and variable geometry twin turbochargers. Changes over the standard Agera R include a larger bore, up form 91.7 mm to 92 mm. The boost is also increased up to 1.8 bar boost pressure from 1.4 bar boost pressure in the Agera R.
Power figures are truly incredible. Koenigsegg quotes 1 Megawatt of power and an 8,250 rpm rev limit. Torque is rated at 1371 Nm from 6000 rpm. Google tells us this equates to a horsepower figure of 1,341 hp. Despite the upgrades, the engine weighs the same in the One:1. Koenigsegg fit a carbon fibre intake manifold with optimized intake tracts (identical to the Agera R) and the same tig-welded ceramic coated Inconel exhaust system manifold with merge collector except with new light weight exhaust tips. The Koenigsegg One:1′s engine takes Koenigsegg’s flex fuel philosophy even further as it now runs on E85 biofuel, Racefuel or normal petrol.
Total weight is just 1,360 kg which is based on the complete car ready to drive with 50% fuel, 100% fluids and without the driver taken into account. This is a total weight saving of just over 70 kg on the Agera R. We won’t embarrass the Bugatti Veyron by mentioning its weight statistics, needless to say the Koenigsegg One:1 trumps it, and then some. Weight distribution is 44% front, 56% rear which is identical to the Agera R.
The transmission is a 7 speed dual clutch gearbox with an electronic differential included. Koenigsegg have chosen not to release a 0-100 km/h time (quite frankly it would be low enough to almost render it irrelevant!). Instead, they quote a 0 – 400 km/h (around 250 mph) time of approximately 20 seconds and 400 – 0 km/h in approximately 10 seconds. The car is also said to achieve a braking distance of just 28 metres from 100-0 km/h.
So, a big part of the Koenigsegg One:1 package is the braking system. Both front and rear brakes are carried over from the Agera R, with power assisted ventilated ceramic discs measuring 397 mm in diameter, 40 mm in width and with 6 ceramic piston callipers at the front. At the rear, the One:1 gets ventilated ceramic discs measuring 380 mm in diameter, 34 mm in width and with 4-piston callipers. The traction control comes with 5 different handling modes.
The Koenigsegg One:1 gets upgrade rear triplex suspension with carbon bevel springs and active shock absorbers. The suspension package includes active ride height and shock absorbing and variable stiffness spring ratios. The carbon chassis and bodywork is 20% lighter due to the use of of M46J & M55J high modulus fibres.
To put the power down, custom made Michelin Cup Tires are fitted each corner with a speed rating of 440 km/h. The measure 19 inches and 265/35 at the front and 20 inches and 345/30 at the rear. These measures combine with revolutionary Koenigsegg Aircore carbon fiber wheels, a different design to those Koenigsegg previously released.
Geneva Motor Show 2014 News
Despite the undisclosed price (certainly in the multiple million price range) there are a number of options. These include one piece racing bucket seats, active shock absorber settings, a full clear carbon body, custom body striping, upgraded audio system, painted calipers, personalized logo on rear hood, anodized black aluminium interior, custom leather One:1 custom luggage set, custom diamond encrusted key, titanium exhaust outlet, active noise cancellation, 3G telematics system and the variable turbo geometry.
Only 6 of these cars will leave the factory. The majority are headed to wealthy Chinese customers, although we have been told that two will remain in Europe! This is what the Koenigsegg One:1 looks like then. Any questions or comments, ask away in the comments box and we will try to answer them in our next post from the Geneva Motor Show 2014 next week!
*source
http://www.gtspirit.com/2014/02/28/o...enigsegg-one1/
Seize is offline
Old 02-28-14, 09:51 AM
Hoovey689
Hoovey689's Avatar
I'm smitten !
So two in Europe, and majority means at least three of the possible four left in China. Hopefully at least one goes to the US
Hoovey689 is offline
Old 02-28-14, 10:04 AM
Seize
Seize's Avatar
Originally Posted by Hoovey2411
I'm smitten !
Don't forget about Dubai. You know how they love supercars over there
Seize is offline
Old 02-28-14, 10:27 AM
rominl
exclusive matchup
rominl's Avatar
I'm smitten !
goose bumps!!!!!!!
let's see, 6 total, 2 in europe. majority in china, meaning at least 3. so that leaves 1 final one for the rest of the world
rominl is offline
Old 02-28-14, 11:19 AM
Hoovey689
Hoovey689's Avatar
Originally Posted by rominl
goose bumps!!!!!!!
Haha you're right guys, we're screwed
Shame cause this thing is
Old 02-28-14, 11:41 AM
rominl
exclusive matchup
rominl's Avatar
i can understand exclusivity but come on, can't make just SIX!!!!!!!!!!!!
rominl is offline
Old 02-28-14, 11:46 AM
Hoovey689
Hoovey689's Avatar
Seriously, how about like 20 or something
Old 02-28-14, 01:58 PM
hlee12
hlee12's Avatar
1400hp @ 1400lb?
that's a flying car.
hlee12 is offline
Old 02-28-14, 03:06 PM
Individual
Individual's Avatar
That thing is bonkers with the official stats! They need to make this into digital form like a new Gran Turismo or Forza game for the rest of us to enjoy. So 0-250mph is the new 0-60mph for hyper cars? It looks like it should be a quick track car too and not just a straight-line monster, I mean damn, 2g's in the corners.
Individual is offline
Old 02-28-14, 03:25 PM
Blackraven
Blackraven's Avatar
I don't think they're using a mechanized assembly line, are they? So everything is hand-built?
If so, then I can't see why they would limit it to only six units....
Old 02-28-14, 03:48 PM
darkdream
darkdream's Avatar
All cars they build are handbuilt. They only want to limit to six units for exclusivity. Many have limited runs of 50-100, so 6 is still small for limited runs.
darkdream is offline
Old 03-01-14, 07:44 AM
Blackraven
Blackraven's Avatar
Ah I see.
Still, if there is someone out there who has lots of money and wants to buy a One:1, then Koenigsegg should continue making it even after the six unit run....
Old 03-01-14, 04:15 PM
Hoovey689
Hoovey689's Avatar
Ah I see.
While I agree with your point, I can see first owners getting annoyed that their car is "less exclusive" than they thought when originally purchased
Quick Reply: Koenigsegg One:1 Hypercar
