HELP. New Car won't start after 3+ month left out in the Winter.
Old 08-27-11, 07:44 PM
turtle11
turtle11's Avatar
If the battery died, then how come i can start it right up without jump starting it? It's running fine without the need to replace it.
turtle11 is offline
Old 08-27-11, 08:51 PM
UDel
UDel's Avatar
What exactly is your issue? Sounds like you bought a new car, it would not start in the cold and you left it over winter without driving it since it did not start and now it starts fine in warmer weather?
If you bought a brand new car then you should have brought it back to the dealership if it did not start, you can take it to a mechanic or auto parts store and they should be able to run a test to determine if the battery, starter, or alternator have any issues. If you don't start a car for 3 months the battery will most likely not have enough charge to start the car and that is why your hearing a clicking noise. You may also just have a bad battery that is not holding a charge correctly if it will not start in cold weather. I can't think of a reason why a car would not start in cold weather but would suddenly work fine in warm weather unless you are talking brutal frigid temps where the battery is not equipped to handle the extreme cold temperatures.
If you don't drive a car for several weeks to several months you can buy a trickle charger that will keep the battery charged without having to start it or jump start it.
UDel is offline
Old 08-27-11, 10:20 PM
scgt652
scgt652's Avatar
Next time make sure you disconnect the battery before leaving the car idle for several months.
You should also inspect the tires to see if there are any flat spots.
scgt652 is offline
Old 08-28-11, 05:40 AM
LexBob2
LexBob2's Avatar
turtle11, are you just messin' with us???
LexBob2 is offline
Old 08-28-11, 09:25 AM
bad co
bad co's Avatar
This thread is a joke hahaha!
bad co is offline
Old 08-28-11, 02:27 PM
Received 2,126 Likes on 1,378 Posts
I left out my new car 3+ month outside doing Winter without garage and when i finally try to start it, it won't start now.
No, couldn't get it to turn on doing the cold, so i just let it sit though the winter until the whether warms up a little. Winter have pass now and it's running fine now. Im just curious why it won't turn on doing that time. Could it be frozen or a lemon?
so which is it, won't start now or running fine now!?
Never jump start it. It's starting again after the whether warm up.
ok, well assuming the battery isn't in great shape for some reason and that it DOES in fact start now that it's warmer (although i've no idea where you are or how cold it was or when, etc.), that's not unusual. a battery has to work MUCH harder in winter than in summer. so in warm weather the battery was 'good enough' to get it started, but in winter, not good enough.
if it was not starting before you left it for 3+ months, why didn't you have it looked at back then?
they don't typically die entirely, they just don't charge as well and don't have enough charge to start the car when it's really cold.
bitkahuna is offline
Old 08-28-11, 05:45 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
i smell a troll....
PureDrifter is offline
Old 08-28-11, 05:56 PM
Justin2JZ
Justin2JZ's Avatar
Easy guys, some people aren't as knowledgeable with cars as others. The OP being a perfect example no offense.
Justin2JZ is offline
Old 08-28-11, 07:39 PM
Nick2JZ
Nick2JZ's Avatar
how old are you turtle?
Nick2JZ is offline
Tony81
IS - 1st Gen (2001-2005)
06-03-15 08:06 AM
Gee2anIS
IS F (2008-2014)
13
05-01-14 07:14 PM
isthrizzy
05-01-13 05:43 PM
TTCUPS
Performance & Maintenance
03-02-05 02:48 PM
Prost
01-25-05 09:56 PM
Quick Reply: HELP. New Car won't start after 3+ month left out in the Winter.
