C&D: Effects of Upsized Wheels and Tires Tested
Guest
Posts: n/a
Weak article, what would have been interesting would be a test of larger yet lighter wheel vs the next size down. We all know the heavier the slower with associated decreases in performance/MPG.
Whereas some claim weight is everything, others will counter that the larger yet lighter wheel would be hampered by the rotating mass being further out, therefore offsetting any performance gained with the lighter wheels.
Increasing the weight of your wheel & tire combo is probably the worst place to add weight if acceleration, braking, handling, or ride comfort is important to you. Increasing the diameter of your wheels allows you to reduce the sidewall height of the tire without altering the diameter. Reducing tire sidewall height increases road "feel" whether wanted or not & reduces impact resistance. (leading cause of sidewall "bubbles") Increased wheel diameter also increases rotational inertia which resists acceleration & deceleration. Moving the mass or weight further from the axle or axis (bigger wheels) increases the leverage the mass has to resist change (acceleration &/or deceleration).
