Which is better, Vtec or VVTI...
I drive an LS 400 pre-98 so I dont have the VVTI engine, but I did test drive a 99, (has it for the newbs), and fell in love with it. Ive driven my friends 01' Acura CL type S with 3.2L Vtec and it seemed pretty fast as well, but it was 2 door and less weight. Im on the fence here about either one.
VTEC and VVTi are similar and both great ways to improve both fuel economy and performance, but I wouldn't decide a car on one vs. the other.
And an LS vs. an Acura CL ... well, there's no comparison.
I think Vtec was the first variable valve timing and lift control mechanism out at its time?
NSX started using this technology in 1990 and VVTI was introduced in 1996.
I think vtec is superior to vvti.
Guest
Posts: n/a
I believe i-Vtec is now continuous so its similar to VVti thus today I don't see one having an advantage.
Car Chat Moderator
I had an Integra GSR with B18C5 motor, the 2 step Vtec, which unlike other Honda vtec made for fuel economy, will give you a sudden bump in HP once it go after certain RPM. It was kind of exciting to drive, but after a while, I get tired of the sudden push, and its requirement of high rpm.
Whereas VVTI, it is so smooth and you don't even feel the change, which I like better, the smooth and linear feel.
Super Moderator
Correct, NSX was the first and amazing to have that tech in 1990. However, Vtec kicks in after a certain RPM range, VVTi is continuous, thus VVTi would be better. For instance VVTi added 40/50 hp from the same 4.0 V-8 in the SC/LS in 1992.
Actually, VTEC was first used in Honda motorcycles, but in the case of Honda automobiles, the first to have VTEC was actually the 88 JDM spec 1.6 Integra and/or JDM CRX.
Anyway, VTEC and VVT-i are not apples to apples. If you want to compare VVT-i to something from Honda, you have to compare it to i-VTEC, and they are still not 100% comparable. You'd have to compare i-VTEC to VVT-iL. Now those are comparable as they to virtually the same thing.
Here is my breakdown, and anyone can research it themsevels.
VTEC > VVT
VVT-i > VTEC
i-VTEC > VVT-i
VVT-iL = i-VTEC
Here is my reason. VTEC varies valve lift and duration, but not cam phasing. VVT-i does not vary valve lift, but varies cam phasing.
i-VTEC now varies cam phasing.
VVT-iL now varies cam lift.
As for how VTEC feels, it just depends on how Honda decided to tune it. On the GR-R and other Honda cars it was almost like and on off switch. You felt the transition. On the NSX, you barely felt VTEC at all. It was tuned for a much smoother transition.
Guest
Posts: n/a
VTEC > VVT
VVT-i > VTEC
i-VTEC > VVT-i
VVT-iL = i-VTEC
VTEC > VVT
VVT-i > VTEC
i-VTEC > VVT-i
VVT-iL = i-VTEC
