Toyota Adds 13 More Models For 2008 Tundra Lineup
Speaks French in Russian
01/10/2008
http://pressroom.toyota.com/Releases...T2008011083847
01/10/2008
January 10, 2008 - Torrance, CA - Toyota has created greater value to its 2008 Tundra full-size pickup truck lineup by adding 13 new models and enhancing standard equipment levels. The 2008 Tundra now offers a choice of 44 models in three cab styles.
Since its introduction in February 2007, Tundra's share of the half-ton full-size pickup truck segment has more than doubled.
"Last year, Toyota designed the new-generation Tundra to exceed truck buyers' expectations for what a full-size pickup can be," said Jim Lentz, Toyota Motor Sales executive vice president. "The 2008 Tundra truly sets new standards for performance, safety, comfort and functionality."
The biggest change for the 2008 Tundra is the increased availability of the two most popular cab styles – Double Cab and CrewMax – with the "Tundra grade," formerly offered only in Regular Cab models, to improve Tundra's reach into the marketplace. Previously, these four-door models were available only in the intermediate SR5 and top-line Limited grades. The new Tundra grade, positioned just below the SR5, is equipped with all of the key standard features consumers expect in their truck, adding up to a great value.
Toyota is bolstering the value of the Tundra SR5 grade Double Cab and CrewMax by increasing standard equipment. For 2008, these models include the previously optional power bucket front seats, AM/FM stereo with 6-disc CD changer, cold kit, heated mirrors, and mud guards as standard at no cost.
The Tundra Limited grade Double Cab and Crew Max models add the formerly optional front and rear parking sonar, cold kit, and mudguards to the standard equipment list. Finally, the Tundra grade regular cab model features a new front-end appearance for 2008, which features a chrome bumper and matte-black grille surround.
Primarily designed, engineered and assembled in America, the formidable
2008 Tundra is available with 4x2 and 4x4 drivetrains and offers three cab styles, three wheelbases, three bed lengths, three engines, and three trim levels.
All Tundra models feature the Toyota STAR SAFETY SYSTEM™ as standard equipment, giving Tundra one of the most comprehensive arrays of standard safety technology in the full-size pickup truck category. The system includes ABS, Electronic Brakeforce Distribution (EBD), Brake Assist, Vehicle Stability Control (VSC) and Traction Control (TRAC).
Toyota introduced its all-new, Tundra full-size pickup truck line for 2007, and for 2008 adds minor refinements to these powerful, hard-working trucks. Tundra offers three cab styles: Regular Cab, four-door Double Cab, and the super-sized four-door CrewMax with the segment's leading rear-seat legroom.
For 2008, the Regular Cab fog lamps are optional on the SR5 grade. The top-line Limited grade gains an optional power memory package for the seats, mirrors and tilt and telescopic steering wheel.
From the side, the Tundra's distinct "barbell" form with pronounced wheel arches conveys the truck's inherent strength. Character lines and fender flares add dimension and strength as well as an unwavering stance. The Tundra grade, SR5 and Limited grade models stand apart with a bold chrome grille surround.
Tundra backs up its tough-truck styling with the performance of an available 381-horsepower 5.7-liter i-Force V8 engine teamed to a six-speed automatic transmission. The 5.7-liter i-Force is one of the most powerful engines to be made available in a half-ton full-size pickup.
Tundra Regular Cab comes standard in Tundra grade and can be upgraded to SR5 with an option package; the Double Cab and CrewMax models are now available in Tundra grade in addition to the SR5 and Limited trim levels. Tundra offers high levels of user technology, including available Bluetooth® cell phone compatibility, high-end JBL audio and an optional navigation system that integrates a wide-screen rear backup camera.
Power for Big Jobs or Big Fun
In Tundra Regular and Double Cab models, a standard 4.0-liter V6 produces 236 horsepower at 5,200 rpm and 266 lb.-ft. of peak torque at 4,000 rpm. The mid-grade option for these models – and standard for the CrewMax models – is Toyota's 4.7-liter i-Force V8 producing 276 horsepower at 5,400 rpm and 313 lb.-ft. of peak torque at 3,400 rpm.
Both the V6 and the i-Force 4.7-liter V8 feature DOHC 4-valve cylinder heads and Variable Valve Timing with intelligence (VVT-i) for responsive power across the engine's operating range. Both engines are teamed with a five-speed automatic transmission that offers greater flexibility than competitors' four-speed automatics. For added driver control, the Tundra five-speed automatic features uphill / downhill shift logic. All Tundra models feature sequential shift.
i-Force 5.7 – A Force to be Reckoned With
The Tundra's 5.7-liter i-Force V8 is available in every model configuration. Specifically engineered for full-size pickup applications, the i-Force 5.7-liter uses a long-stroke design (stroke dimension of 4.02 in. is more than the bore width of 3.70 in.). As a result, in addition to its impressive 381 horsepower at 5,600 rpm, the i-Force 5.7 produces 401 lb.-ft of peak torque at 3,600 rpm. The i-Force 5.7 V8 uses aluminum for the cylinder block and DOHC heads. A Dual Independent VVT-i system controls valve timing and overlap on both the intake and exhaust valves independently of each other, which helps optimize power and fuel efficiency while minimizing emissions.
All Tundra engines are equipped with the Acoustic Control Induction System (ACIS). Butterfly valves inside intake manifold switch the length of the intake runners in two stages, based on rpm and throttle angle, to improve efficiency across the engine speed range.
Tubular stainless steel 4-2-1 exhaust headers flow into a full stainless steel exhaust system with laser-welded, high-capacity mufflers for optimal efficiency and a powerful sound. Both i-Force V8s feature a crank-hold electronic starter control that uses a "twist and release" ignition switch to prevent failed starts and "grinding" on a re-start attempt. Both Tundra V8 engines meet the Ultra-Low Emissions Vehicle, or ULEV II, emissions certification.
The i-Force 5.7-liter is teamed exclusively with a six-speed automatic transmission. Shift logic adapts the transmission's shift maps to driver input. Both Tundra transmissions use Toyota "WS" fluid with a flat viscosity/temperature curve (cold viscosity is close to warm viscosity). This fluid reduces friction and wear, enables faster vehicle warm-up, and never needs to be replaced. Like the five-speed, it also features a transmission fluid warmer, which quickly brings the transmission fluid up to operating temperature, in order to optimize cold-weather performance.
Chassis Built for Capability, Control and Ride Quality
There are three Tundra wheelbases: 126.8 inches for Regular Cab/standard bed models; 145.7 inches for Regular Cab/long bed, Double Cab/standard bed and CrewMax models, and a massive 164.6 inches for Double Cab/long bed models. Tundra's advanced TripleTech frame uses wide, full-boxed frame rails for the front portion, reinforced C-channel under the cab and an open C-channel underneath the bed to maximize strength, ride quality and durability.
The double A-arm front suspension uses coil-over spring shock units, and a front-mounted steering rack helps enhance steering feel and response. The rear suspension uses staggered shocks mounted outboard of the springs to improve the shocks' dampening efficiency. Spring rates have been tuned to provide a flat vehicle stance when fully loaded, and the trapezoidal shape of the rear frame section provides "toe-out" mounting points for the rear leaf springs, which provides confident towing under a full load.
The Tundra is equipped with one of the largest standard wheels in the segment – 18 x 8 inches with 255/70 R18 tires. Limited grade models step up to standard 18 x 8-inch aluminum-alloy wheels with wider 275/65 R18 tires. As an option, Limited models can be outfitted with factory-optional 20-inch alloy wheels with 275/55 R20 tires. An optional TRD (Toyota Racing Development) Off-Road Package is available and combines off-road tuned suspension featuring Bilstein gas-charged mono-tube shock absorbers; 275/65 R18 B.F. Goodrich Radial T/A off-road tires on unique 18-inch alloy wheels; fog lamps, and special graphics.
The Segment's Most Advanced Brakes
All Tundra models employ one of the segment's larger and more sophisticated standard braking system. The four-wheel disc brakes use large ventilated rotors: front rotors measure 13.9 inches in diameter and 1.26-inches thick, with four-piston calipers; rear rotors measure 13.6 x 0.71-inch and use two-piston calipers.
Anti-lock brakes (ABS) with Electronic Brake-force Distribution (EBD) and Brake Assist (BA) are standard on all Tundra models. EBD optimizes brake pressure at each wheel for greater control under braking, especially when cornering. The Brake Assist system is designed to determine if the driver is attempting emergency braking. If the driver has not pressed firmly enough on the brake pedal to engage the ABS, the system supplements the applied braking power until pedal pressure is released.
Found on all of Toyota's SUVs and the Tundra pickup, the STAR SAFETY SYSTEM™ gives these vehicles company's most advanced traction-enhancing dynamic control. The system includes ABS, Electronic Brakeforce Distribution (EBD), Brake Assist, Vehicle Stability Control (VSC) and Traction Control (TRAC).
The standard Automatic Limited-slip Differential (Auto-LSD) helps provide better acceleration in deep sand or mud and on mixed friction surfaces. Compared to a conventional mechanical limited slip differential, the Auto-LSD system is much more responsive and has much better wear characteristics. The combination of Auto-LSD and Vehicle Stability Control (VSC) as standard equipment on every model is a significant "first" in the segment.
The Tundra's VSC system integrates traction control (TRAC) on all models, and enhances traction on or off-road by helping to keep the vehicle going on its intended course. VSC detects front-wheel slide and rear-wheel slide during cornering and attempts to control either condition with throttle intervention and/or by braking individual wheels. The integration of these technologies also brings with it driver-selectable versatility to tackle just about any road surface or driving condition. In "normal" mode, VSC, TRAC and Auto-LSD are all functioning to help enable traction and control capability. "TRAC Off" activates Auto-LSD, to help extricate the Tundra from extreme conditions. The "VSC Off" mode turns off all of three of these systems.
Tundra is the first full-size pickup to feature standard front seat side and roll-sensing side curtain airbags in all models. Three-point seatbelts and adjustable headrests for all seating positions are likewise firsts in the segment. The front seatbelts include pretensioners and force limiters.
4x4 Capability
The combination of Auto-LSD and VSC gives even the two-wheel drive Tundra models far better traction in more situations than could be expected from the typical 4x2 pickup truck. For more demanding conditions, Tundra's 4x4 configurations offer a part-time, electronically-controlled four-wheel drive system featuring a six-pinion planetary reduction gearset to provide 4x2, 4x4 Hi and 4x4 Lo ranges. The driver selects the drive mode using a dial on the dash.
The rear differential in V6 and i-Force 4.7-liter V8 Tundra models features a 9.5-inch ring gear, and the i-Force 5.7-liter models step up to a 10.5-inch ring gear – one of the largest in the segment. "Face hob" gear cutting for ring and pinion gears yields stronger tooth form and a greater engagement area for increased torque capacity, reduced wear and reduced gear noise.
Comprehensive Towing Package
The Tow Package, standard on all Tundra i-Force V8 models, increases towing capacity significantly, up to 10,800 pounds, depending on the model and drivetrain (see specification sheet). The Tow Package starts with a one-piece towing receiver integrated into the frame prior to bed installation. The structure runs nearly 2 feet down the length of the frame, and attaches to each side of the frame around the rear spring shackles' cross-member with 12 bolts. Tow Package rear springs help provide level full-load rear suspension height and maintain full range of suspension travel. The Tundra can stay level even with 1,000 lbs. of tongue weight or payload.
The Tow Package also upgrades Tundra's cooling and electrical systems, with a supplemental water-to-oil engine oil cooler to handle the demands of towing under a full-load. A power steering fluid cooler is added below the radiator. Electrical upgrades include an under-dash connector prewire for a third-party trailer brake controller, both a seven-pin and a four-pin trailer brake connectors near the hitch, and an up-rated alternator.
The final touch is a set of optional telescoping towing mirrors (available on 5.7-liter V8 models only). The six-speed automatic transmission in the V8, 5.7-liter Tundra, gains a TOW/HAUL shift mode, selectable by a dedicated switch. The TOW/HAUL shift mode applies specific logic for adjusting the throttle sensitivity and for transmission upshift and downshift control, favoring and holding lower gears when accelerating or decelerating to help enhance driver control and safety.
Three Bed Sizes
Tundra Regular Cab and Double Cab models are offered in standard bed (78.7-inch) or long bed (97.6-inch) configurations; the CrewMax comes with a short bed (66.7-inch). In all models, the bed measures 22.2 inches deep. The Tundra's lockable all-steel tailgate, with tailgate assist, can be effortlessly opened and closed with just two fingers – and it can easily be removed.
A standard cargo lamp provides generous illumination at night. A Deck Rail System, standard on Limited grade models and available on all others, adds to cargo bed versatility. Featuring four adjustable tie-down cleats connected to the rails of the all-steel bed, the rail system can be used to secure many types of loads, with a 220-lb-rating per attachment.
The roster of Genuine Toyota Accessories available for the Tundra includes a number of cargo bed enhancements, including a tonneau cover, bed mat, bed liner, bed extender, Deck Rail accessories, storage boxes, cargo divider, tie-downs and utility hooks.
Front Office "Command and Control"
Toyota designed the next-generation Tundra's interior for "true truckers," customers who put the greatest demands on their pickups, including ranchers, foremen and construction workers.
The driver is surrounded by a U-shaped "command and control" center that helps provide an unobstructed view of the road and gauges, while keeping all *****, switches and buttons within easy reach. Dash and door panel forms emphasize function yet are far from austere. Because many true truckers wear protective clothing as part of their jobs, the Tundra features large door handles and easy-to-turn control ***** that can be operated even while wearing work gloves.
Owners who spend a lot of time on the job site often use their trucks as mobile offices, so Toyota gave Tundra increased storage capacity for this usage. The 3.4-liter upper glove box can hold a standard Thermos™ bottle, with additional space available in the 9.5-liter lower glovebox.
The huge center console on bucket-seat models can hold a laptop computer or hanging file folder storage – a pickup truck first. For optimal comfort, the center console armrest features a four-inch slide range. The Tundra cockpit provides two 12v DC power outlets, one on the dash and one in the center console. CrewMax models add a third outlet at the rear of the center console. The outlets remain live for up to two hours after the ignition is switched off.
Room, Comfort and Storage for the Whole Crew
The Tundra Regular Cab offers more behind-the-seat storage than other pickups, and the Double Cab features front-hinged doors that open to 80 degrees for easy passenger access. The Tundra Double Cab models provide a roomy rear seat with a 22-degree backrest angle and 34.7 inches of rear legroom for comfort on par with some midsize sedans.
The Tundra CrewMax provides best-in-class maximum rear legroom at 44.5 inches. CrewMax rear seat versatility is enhanced with the segment's first reclining and sliding rear seat. A 10-inch slide range allows the owner to custom-tailor passenger comfort and room for onboard cargo. CrewMax models provide additional storage under the rear seat.
On Double Cab and CrewMax models, the standard power rear windows retract completely into the doors. The Regular and Double Cab models offer an optional split sliding rear window to enhance interior ventilation, with a power vertical slide-down rear window standard on CrewMax models. The Tundra offers richly textured fabrics and deep-grain leathers available in four colors. As another nod to refinement, CrewMax models offer an optional power tilt/sliding moonroof with an automatic variable-position wind deflector.
Toyota maximized space and added convenience within all Tundra cabs. A concealed compartment to the right of the shift lever can hold a Thomas® guidebook. The built-in toolbox behind the rear seat in all models provides clean, accessible storage for the jack, handle and lug wrench.
In Double Cab and CrewMax models, the rear seat backs fold in an easy one-hand operation to provide a flat floor storage area. The front doors feature large storage pockets and can also hold two 22-ounce bottles. Rear doors on Double Cab and CrewMax each hold one bottle.
Interior Leaves the Job Site Behind
All Tundra-grade and SR5 grade models come standard with a versatile dual-zone manual climate control system with a seven-speed blower, sync-mode and a replaceable dust and pollen filter. Limited grade models feature an automatic dual-zone automatic climate control system.
The four-spoke steering wheel features standard audio controls in Limited grade and are available on Double Cab models equipped with either the optional JBL audio system or optional navigation system.
The available manual tilt and telescoping steering wheel is a first in the segment, as is the available power tilt and telescoping steering wheel found on Limited models. Showing Toyota's attention to detail, the rolling-ball telescoping steering shaft improves wheel-tilt feel compared to splined-sliding types.
Standard High Solar Energy Absorbing (HSEA) glass helps filter solar heat and most UV (skin-sensitive) light energy entering the vehicle, reducing occupants' sun exposure, helping to keep the interior cooler and enhancing durability of interior materials. Limited grade models receive standard IR-cut glass, further reducing solar levels from infrared rays.
Tundra Limited models give up none of the work ethic and add more refinement than ever seen on a Toyota pickup. A few more notable features that distinguish the Limited grade models include: chrome, power-retractable, heated auto-dimming side-view mirrors; leather-trimmed, heated power-adjustable front bucket seats (10-way for driver, 4-way for passenger); and rear door privacy glass.
Features borrowed from luxury sedans include Optitron meters and a multi-information center featuring selectable readouts for the clock, outside temperature, and fuel economy. A user-customizable interface allows the Tundra owner to set keyless entry feedback; door unlock mode (one press/two press); automatic door locking programming; headlight auto-off timer, and the interior light timer.
Options to Entertain and Inform
Tundra-grade models come with a standard AM/FM/CD stereo with six speakers (four speakers on Regular Cab models) and an audio input jack; SR5 models add a six-disc in-dash CD changer, and offer an available JBL AM/FM audio system with six-disc in-dash CD changer, 440-watt 5.1 channel surround sound, 10 speakers (12 in CrewMax), Bluetooth® compatibility, and steering wheel audio controls. This system (with 10 speakers) is standard on the Tundra grade. All Tundra audio systems can play MP3/WMA formatted CDs.
CrewMax models offer an optional Rear Seat Entertainment (RSE) system that combines a nine-inch wide-screen LCD monitor, DVD player, two sets of wireless headphones and a remote control. An available DVD navigation system includes a JBL audio system and integrates a rear backup camera. The camera automatically projects an image of what its lens can detect behind the vehicle onto the navigation system's LCD screen when reverse gear is engaged, useful when backing up the Tundra to a trailer, or for positioning a boat trailer on a launch ramp. A multifunction rear view mirror, standard on Limited grade models and optional for others, combines an electrochromic auto-dimming mirror with a digital compass and HomeLink® transceiver.
Backed by Toyota
Toyota's 36-month/36,000-mile basic new-vehicle limited warranty applies to all components other than normal wear and maintenance items. Additional 60-month warranties cover the powertrain for 60 months/60,000 miles and corrosion perforation for 60 months with no mileage limitation.
4x4 Capability
Three Bed Sizes
Backed by Toyota
Cliff notes? Toyota wins the prize for longest press releases!
I think out of all that drivel this is the only 'new' part:
All these SUVs, Pickups and not one single sports car or something that is fun to drive, they don't even have a sporty car. Tons of different SUVs and pickups and a few very boring sedans is what the masses want and they are very successful.
Secrets
Toyota had huge hopes for the second-generation Toyota Tundra when it launched the truck in 2007, including plans for two high-performance versions that we'll likely never see, according to sources with knowledge of the trucks.
The current 2007-10 Tundra was designed from the ground up to compete with full-size pickups from Chrysler, Ford and GM. On paper, the story was compelling. The Tundra featured a strong 5.7-liter V-8, could tow up to 10,800 pounds and was available in regular, extended-cab and crew-cab configurations. Toyota was so confident in the strength of its new truck and the American truck market that it invested more than $1 billion to build a dedicated assembly plant in Texas with the capacity to build 200,000 Tundras a year.
Nearly all of the Tundra's manufacturing and sales volume would have come from mainstream models, but Toyota's U.S. management had plans to add two halo trucks around 2009 that could have lifted the Tundra's image in the eyes of street truck and off-road enthusiasts.
The first specialty Tundra was a powerhouse track truck that would have closely resembled the Toyota TRD Tundra Street Concept. Toyota used the 2004-06 Dodge Ram SRT-10 — which could go from 0 to 60 mph in about 5 seconds and ran the quarter-mile in the 13 seconds — as its benchmark.
The single-cab hot rod Tundra would have come from the factory with today's dealer-installed TRD supercharger, boosting the 5.7-liter V-8's 381 horsepower and 401 pounds-feet of torque stock output to a phenomenal 504 hp at and 550 pounds-feet. It also would have featured a lowered suspension and unique 22x10-inch forged rear wheels (an inch wider than the TRD Street Concept's) and custom rear brakes. The wheel design has never been publicly shown.
But the really slick feature on Toyota's planned Dodge Ram SRT-10/Ford SVT Lightning fighter was something called Competition Mode. With the push of a button, the Tundra's vehicle stability control system would be temporarily fully disabled, so you could tear up the track without throttle or brake intervention and without redundant in-cabin warning beeps that tell you when you've lost traction. In comparison, today's Tundra requires three pushes of the stability control button to turn off most, but not all, electronic nannies.
The second specialty Tundra was a long-travel suspension, go-fast off-road pickup made for tearing up desert trails and washes. If that sounds like the Ford F-150 SVT Raptor, it should. The two trucks would have competed head-to-head against each other. But Toyota wasn't following Ford's lead. It was coincidentally developing its Baja-style Tundra at the same time Ford was working on the Raptor.
The long-travel Tundra would have differed from the Raptor in one key aspect. Toyota planned to borrow the rear independent suspension from the full-size Toyota Sequoia SUV, which shares most of its platform with the Tundra, so it could have ditched the standard rear live axle and leaf springs. Inspiration for that idea came straight from Toyota's experience sponsoring legendary Baja off-road racer Ivan "the Ironman" Stewart.
Before either Tundra could receive approval, the bottom fell out of the U.S. auto industry as fuel prices spiked and the housing market and economy crumbled. The Tundra came close to meeting its annual sales goals in the first year but has missed badly each year since, suffering from the effects of both the economy and high-profile quality and safety issues. Along with the loss in sales was a loss in confidence that killed both special models for the foreseeable future.
Cycle Savant
Ever noticed that American-build Toyota vehicles (such as the Camry, Avalon, and Tundra) have more model designations and options than Japanese models?
Because there is a very expensive fee from Japan whenever a car is built with certain options for the U.S. In other words, the more personalization/customization, the more expensive the car will be. Do that to a car built across a 8000 mile ocean made with Japanese yen, and it's gonna get pricey. But build cars for the U.S. in the U.S, and you don't get the extra cost of manufacturing, distribution, and delivery.
Think about and compare to Audi and Porsche prices. They've got plenty of options. See how prices can add up when you give more choices?
How about they add those 2 models as well?
Gojirra99
10-03-07 02:09 PM
