Plane Crashes Into SUV At Airport
Lexus Connoisseur
http://www.nbc4.tv/news/9282536/detail.html
Originally Posted by NBC4 LA
OXNARD, Calif. -- A small plane crashed into a black sport utility at the Oxnard Airport, authorities say.
Authorities said the plane lost power during takeoff. The pilot attempted to land shortly after taking off and slammed into the vehicle, authorities said.
Investigators said a mother and a 2-year-old child were inside the SUV. They were transported in an ambulance to a hospital.
The single-engine Piper collided with the passenger's side of the SUV, which sustained heavy damage to its front quarter-panel and windshield. The SUV was traveling on east Victoria Avenue.
The crash is under investigation.
Lexus Connoisseur
Just another day. 2nd wierd automobile accident all in one day.
no wonder I couldn't go up Victoria...I was driving the Toyota shuttle picking up a customer, and I wanted to go back to the 101...that totally screwed my day. Besides, the traffic in the area really sucked
Originally Posted by GS300Rich
Imagine that thing falling out of the sky and slamming into you
This is reporting that it was a Lexus SUV...(GX?)
http://www.kcoy.com/news/local/story...0b5f33&rss=143
Hope all recover.
Hope all recover.
With a small aircraft, depending on aircraft and weather conditions, there are a number of different things that can cause power failure on take-off ( I am a licensed pilot myself ) but one of the most common things is simply an inadequate check ( or NO check ) for water in the airplane's fuel tank during the preflight. Water in a plane's fuel tank, being heavier than gasoline, tends to settle and collect in the bottom of the tanks....which are usually in the wings. A special drain **** in the bottom of the tanks allows the pilot ( or pre-flighter ) to take a couple of fuel samples in a small, transparent plastic container and check for the correct color ( different fuel grades are dyed different colors ) and for clear, water bubbles. You keep taking samples until there are no more bubbles. If you DON'T get all the water out, you may not notice it at first during starting, taxi, and runup, but the vibrations and flapping of the wing during takeoff will shake the water bubbles up and then the gravity-feed or fuel pump will pick them up and feed them through the carburator or fuel injectors into the engine....and then of course the engine stalls....sometimes only a couple of hundred feet off the ground, and you have to set the plane down very quickly on the best piece of ground you can get to....and at low altitude and low speed you often don't have many options to choose from.
Guest
Posts: n/a
Originally Posted by is350
its a honda pilot.
Knowing Honda ricers, the Pilot (not the plane pilot but the Honduh guy) took his SUV to the airport to see if it could fly, and crashed into an actual plane flown by an actual pilot.
Originally Posted by 1SICKLEX
Now this is ironic. A PLANE hits a SUV called "Pilot".
