Mercedes-Benz CLS 63 AMG Details & Edmund's First Drive . . .
Super Moderator
Text & Photos courtesy DaimlerChrysler AG
edited 05-02-2006
Unique blend of power and design
The newly developed 6.3-litre engine accelerates the car from 0 to 100 km/h in 4.5 seconds
Technology borrowed from motor racing
Sports suspension with high-performance brake system
AMG bodystyling and exclusive interior appointments
With its impressive performance, dynamic design and exclusive equipment, the new CLS 63 AMG from Mercedes-AMG is a highly unusual automobile. The unique four-door Coupé is powered by a 6.3-litre V8 engine that was completely developed by AMG. With an output of 378 kW/514 hp and a maximum torque of 630 Nm, the new AMG power pack guarantees the very best in driving performance: the CLS 63 AMG accelerates from 0 to 100 km/h in 4.5 seconds and reaches 200 km/h in 15.1 seconds. The vehicle’s top speed is electronically limited to 250 km/h.
AMG’s new 6.3-litre V8 engine is the only one in the world to combine a high-revving design with generous cubic capacity. Developed completely independently by AMG, the high-performance engine has around 20 percent more torque than comparable naturally aspirated engines in this output class. Manufactured completely out of high-strength aluminium, the V8 naturally aspirated engine features a number of technologies borrowed from motorsport, thus impressively documenting the racing sport tradition of AMG. The vertical arrangement of the intake and exhaust ducts as well as the use of a new variable intake manifold with two integrated throttle valves ensures that the cylinders are optimally charged.
Bucket tappets in the cylinder heads make a rigid valvegear possible, and therefore also high engine speeds. Variable camshaft adjustment, a particularly rigid closed-deck crankcase and cylinder bores with the revolutionary new TWAS coating are just some of the other prominent features of the cutting-edge V8 engine made by Mercedes-AMG.
The unique combination of a high-revving design and large engine displacement brings together the best of two worlds: exciting responsiveness and at the same time powerful torque at low engine speeds. A high level of agility at all engine speeds brings home to the driver of the CLS 63 AMG the emphatically sporty character of the vehicle. At 2000 rpm, the AMG V8 already delivers an impressive 500 Nm to the crankshaft. The maximum torque of 630 Nm is available at 5200 rpm.
The new AMG eight-cylinder powerplant delivers dynamic acceleration, fast sprinting power and the highest level of pure driving pleasure. With the AMG’s new, sporty and powerful sound, which was perfected during extensive test series, the eight-cylinder unit from Affalterbach offers the thrill of a naturally aspirated, high-rpm V8 engine — which every driver can feel and hear at low, medium and high engine speeds.
The electronically controlled fuel supply system with newly developed components operates at a pressure of 3.8 to 5.0 bar depending on requirements. The fuel pressure adapts immediately to the desired performance level and external temperature. Following a command from the accelerator pedal, it takes just milliseconds for the vehicle electronics to adjust the pressure accordingly. This control system guarantees a spontaneous response and sporty propulsion at any engine speed and load range.
AMG SPEEDSHIFT 7G-TRONIC with steering-wheel gearshift paddles
AMG SPEEDSHIFT 7G-TRONIC takes care of the power transfer in the new CLS 63 AMG. The driver can select the fully automatic or manual setting and change gears using the selector lever on the new silver-coloured AMG aluminium gearshift paddles. The seven-speed automatic system adapts itself to the driving style — be it dynamic or more laid-back. Accessible via a switch in the centre console, the driving modes “S” (Sport), “C” (Comfort) and “M” (Manual) in the new CLS 63 AMG each have different gearshift characteristics and speeds. Gear-changing time in “S” mode is about 30 percent faster than in “C” mode — and in “M” mode it is up to around 50 percent quicker.
If manual mode ("M") is selected, the driver also benefits from the V8 engine's immense pulling power, since automatic downshifts are prevented, even at full load or when the kickdown position is reached. In other words, the driver can be sure that the selected gear will remain engaged. Selecting manual mode also prevents AMG SPEEDSHIFT from performing an automatic upshift when the engine speed limit for a particular gear is reached. In manual mode ("M"), the new AMG instrument cluster displays the currently selected gear, including a shift prompt. In this way, sportier drivers can make the most of the considerable power at their disposal. When the engine speed approaches the lower rpm limit, the transmission downshifts.
AMG sports suspension based on AIRMATIC DC
The power package is augmented by the AMG sports suspension as well as by the high-performance AMG braking system from the CLS 63 AMG. The engineers at Mercedes-AMG have developed a new sports suspension that is based on the semi-active AIRMATIC DC air suspension with the adaptive damping system (ADS II). Both the springs and the shock absorbers have been significantly stiffened. In addition, changed characteristics for the three stages of the AMG shock absorbers mean that body movements are reduced. Because of the automatically self-levelling suspension at all wheels, spring travel is always the same even when the vehicle is fully loaded. In addition, thicker stabilisers help reduce body roll when cornering at high speeds.
Depending on the driver’s wishes, AIRMATIC DC imbues the CLS 63 AMG with either very sporty or more laid-back handling characteristics. The shock absorbers and springs instantly adapt to the current driving situation, but can also be manually modified in three stages at the touch of a button.
High-performance composite AMG front brakes
The CLS 63 AMG features a new, high-performance, composite brake system at the front. Internally ventilated, perforated brake discs all around provide impressive deceleration and high fading resistance. The vehicle’s wheel/tyre combination also contributes to its high level of dynamic handling. The 8.5 and 9.5-inch wide, titanium grey, high-sheen 18-inch AMG light-alloy wheels in a new five-spoke design are fitted with wide-base tyres in size 255/40 and 285/35.
In line with the sporty development of the new AMG models with the naturally aspirated V8 engine, the Electronic Stability Program is not activated in the CLS 63 AMG when in Off mode. However, the ESP® Off mode is intended only for very sporty drivers who are experienced in highly dynamic driving and who can manoeuvre the AMG vehicles on closed-off tracks even in extreme situations. Even in the ESP® Off mode, however, all of the ESP® functions are restored immediately when the brake is activated. It remains the case that every AMG vehicle meets the same standards as any other Mercedes-Benz series-produced vehicle in terms of Mercedes-Benz core values such as active safety.
Muscular AMG bodystyling for a superlative Coupé design
The CLS 63 AMG’s superlative Coupé design is defined by the muscular AMG bodystyling, including the powerfully contoured front apron with large air inlets and circular fog lamps, side skirts and a distinctive rear apron with the traditional AMG design. The car is made even more distinctive by the unique radiator grille with three powerful, silver-painted louvres as well as by the “6.3 AMG” lettering on the front wings. The stylishly integrated AMG spoiler lip on the boot lid reduces the lift acting on the rear axle by about 30 percent, which contributes to better driving stability at high speeds. The chromed, oval twin tailpipes of the AMG sports exhaust system provide visual and acoustic highlights. The CLS 63 AMG naturally complies with all of the usual emission limits, including EU 4. It also meets the specific requirements on the U.S. market, such as the LEV II standard, the on-board diagnosis II and oxygen sensor diagnosis.
Comprehensive range of high-quality standard equipment, including nappa leather upholstery
The equipment for the CLS 63 AMG stands out due to its combination of exclusive sporty design, high-quality materials and superb workmanship. The AMG sports seats provide a multicontour function and feature the characteristic AMG upholstery piping and perforation pattern with double stitching. In addition, they are equipped with seat heating, an AMG nameplate and Alcantara inserts at the shoulder level that optimise lateral support while cornering at higher speeds. Both the driver and the front passenger can fully adjust the seats electrically, and a memory function makes it possible to store various settings.
The car’s comprehensive range of high-quality appointments also includes top-quality nappa leather in three different colour combinations at all seats, the door centre panels and at the centre armrest; the ergonomic AMG sports steering wheel with new AMG gearshift paddles made of silver-tone aluminium; chrome-plated door sill panels bearing the AMG logo; and the AMG instrument cluster with its 320 km/h speedometer.
Still another new feature is the AMG instrument cluster’s main menu display: the menu shows the currently selected gear including an upshift prompt in the manual ("M") mode, as well as either the engine oil temperature or battery voltage and the RACETIMER. This new function enables the driver of the CLS 63 AMG to measure lap times on an enclosed track. RACETIMER also stores the time of the fastest lap, the average and top speed as well as the lap distance.
Perfected safety with standard PRE-SAFE®
Like all the other variants of the Mercedes-Benz CLS-Class, the new CLS 63 AMG benefits from the extensive model enhancements which guarantee optimal driving safety. PRE-SAFE®, for example, the award-winning anticipatory safety system offered exclusively worldwide by Mercedes-Benz, has been included as standard equipment. PRE-SAFE® recognises a potential accident situation in its early stages. If braking deceleration exceeds a certain level or the vehicle threatens to go into a skid, the system tensions the front seat belts as a precaution, adjusts the position, height and cushion/backrest angle of the front passenger seat, and closes the side windows and sliding sunroof to leave only a small gap.
The market launch of the new CLS 63 AMG is scheduled for June 2006.
specs. & more pics HERE
source : germancarfans
Super Moderator
Originally Posted by magneto112
Silver makes this sexy car look very plain.
Just an amazing car .............I would pick it over the M5 bec its faster and looks 100x better inside/out, even though the M5 is more of a hard core sports car.
