Build Threads Details on Club Lexus 2GS owner vehicles
2jzgte build/ wire tuck/ fuse box relocation
Old 07-31-16, 12:12 AM
Honda525
Honda525's Avatar
Default 2jzgte build/ wire tuck/ fuse box relocation
Started my build early this month and after reading all the posts on other peoples builds sounded like fun posting about it along the way. Also not to many people do wire tuck and fuse box relocations with the steps it took to do so! So i will do my best to help on that topic along the way. Here is a couple pics of what i habe done so far
When i started taking the engine out
Engine out
Picked up the motor about a week later
Toyota supra Radiator upgrade
Lil Single turbo kit i picked up
Hks timing belt upgrade
New belt, idler pully, tensioner, and water pump
Intake manifold mounted and waiting on new lower timing belt cover/ pulleys amd maybe a cam gear why not at this point haha
Will take some more pics tomorrow with pulleys on
Started stripping the engine bay to get it ready for paint. Im going with midnight purple pearl from the gtr also going to throw in some purple rainbow flake in the clear. paint code is LP2 for anyone wanting to know and this is what the color will look like
After getting most of the wires amd fuse boxes out
Quick wipe down before i pressure wash it
Will add some more pics of progress tomorrow!!!
Old 08-01-16, 07:34 AM
SoCal Cyco
SoCal Cyco's Avatar
nice!!! this ought to be good
Old 08-01-16, 10:30 AM
sakataj
sakataj's Avatar
i concur.... i always wanted to wire tuck my GS
Old 08-01-16, 01:37 PM
Hayce
Hayce's Avatar
Good luck - slightly bigger job than a Honda!
Old 08-01-16, 02:01 PM
Honda525
Honda525's Avatar
Just a lil haa
Old 08-02-16, 04:38 PM
Honda525
Honda525's Avatar
Started taking apart my wireing to figure out what wires need to stay and what wires need to be cut so i can relocate the fuse box
Old 08-03-16, 03:22 PM
o7iS250
o7iS250's Avatar
In for this because I would also like the clean up the bay when I do my swap! You don't see many tucked/clean gs bays
Old 08-04-16, 12:48 AM
Honda525
Honda525's Avatar
For reals no one ever takes the time ti do it andr if they do they dont share what they did.
Old 08-04-16, 12:50 AM
Honda525
Honda525's Avatar
Going on vacation till the 14th then ill be on grind mode cause i need this done and running by the end of the month!!!
Old 09-06-16, 06:34 PM
o7iS250
o7iS250's Avatar
welllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllll.
Old 09-06-16, 06:40 PM
Honda525
Honda525's Avatar
Default Update on my build
Im holding off on extending my wire due ti an emergency sad to say so for now i threw the motor in
Old 09-06-16, 06:47 PM
o7iS250
o7iS250's Avatar
Ahhh stuff happens, hopefully the emergency you speak of isn't too bad. I've been seeing everyone installing their turbo minus the compressor housing at first.. why is that?
Old 09-12-16, 01:11 PM
sakataj
sakataj's Avatar
we used to do it like that incase the housing hit the firewall, you could install turbo with motor and test fit the housing then bang out the firewall if needed
Old 09-13-16, 12:40 AM
Honda525
Honda525's Avatar
Just did that cause it was fron another car and the piping that was already welded on wouldnt clear
Old 09-13-16, 06:45 PM
Hayce
Hayce's Avatar
That doesn't make sense to me. Turbine housing maybe for banging out the firewall but if you don't have that on, it's not bolted to the manifold so..
Most of the time the compressor cover is left off it's to clock it. Personally, I've always left it on (compressors are fragile!) backed the bolts off and carefully clocked it around.
good luck OP, super keen to see this turn out.
Quick Reply: 2jzgte build/ wire tuck/ fuse box relocation
