Build Threads Details on Club Lexus LS400 owner vehicles
David's 1998 Lexus Ls400
Old 02-22-17, 07:58 AM
  #76
Scraape
Scraape's Avatar
Originally Posted by ultm8mind
How you part all this out? Is this everything needed and the cheapest way to do it? Thinking about doing my belt and water pump when I redo my alternator...
I was looking for a timing belt kit on ebay, preferred to get all OEM parts, so i just searched for the correct Toyota Part #'s for each part and referred to what was included in the timing belt kits on ebay.
There's definitely other parts you could replace as well I suppose.
Old 02-22-17, 10:40 PM
  #77
ultm8mind
ultm8mind's Avatar
Well man, I plan on doing the water pump, timing belt, alternator, extended lug bolts for fronts, brake rotors and pads (all around), trans flush, diff flush and paint a bumper I scooped up for my rear.
Old 03-10-17, 08:29 PM
  #78
Scraape
Scraape's Avatar
hell yeah, found a new OEM intake airbox thing on ebay, and not for a bad price. $100 shipped, brand new, good deal. All the other places i saw had them for ~$200.
My car needed a new one of these badly because the tubing to the throttle body is cracked, as well as the two nipples on the airbox are broken off, vacuum leak central, lol.
Old 04-02-17, 01:06 PM
  #79
Scraape
Scraape's Avatar
timing belt job time. Should be very fun. Luckily I have this forum to refer to for tutorials.
Old 04-24-17, 04:41 PM
  #80
Scraape
Scraape's Avatar
cars been back on the road for a couple weeks now, no issues, no leaks as far as I can tell . Runs and sounds much better than it did before. Definitely glad I dished out the money for the 90k maintenance!
hotdawwg (04-24-17)
Old 04-24-17, 09:15 PM
  #81
ultm8mind
ultm8mind's Avatar
Nice, I'll come through so we can do mine, haha
Scraape (04-29-17)
Old 04-29-17, 07:18 PM
  #82
Scraape
Scraape's Avatar
lol as long as your cam seals aren't leaking, isn't hard at all lol
Old 07-31-17, 11:55 AM
  #83
saleenssc
saleenssc's Avatar
Things i've replaced so far:
Fuel Filter
Tranny Filter
Spark Plugs (NGK Iridium)
Valve Cover Gaskets/Spark Plug Grommets
Alternator
Radiator
Coolant Temp Sensor
PCV Valve
Transmission Mount
VVT Solenoid
Oil Control Valve
I've cleaned the MAF, changed the air filter, cleaned the air mix path and the throttle body.
Coolant Temp Sensor Change:
Attachment 442982
Attachment 442983
Did you use a washer with the new Coolant temp sensor ? If so did the washer come with your ECT sensor? I ordered one directly from toyota for my 98 part number 89422-30030 but it did not come with any washer. AS a matter of fact the old ECT sensor that i removed from my 98 did not use a washer. Could you please provide details on the washer. Cant tell in the picture if there is a washer being used. Thanks
Old 07-31-17, 03:40 PM
  #84
Scraape
Scraape's Avatar
if you ordered the part directly from toyota then i would imagine they don't come with washers.
I ordered some generic brand coolant temp sensor and don't believe mine had a washer either
Old 08-25-17, 05:30 PM
  #85
Scraape
Scraape's Avatar
put a bunch of miles on my car is the past couple months with trips down the Boca Raton, FL as well as Topton, NC to watch the eclipse. It's now at 272,xxx miles.
Unfortunately in the process my harness on drivers side fender got snagged and torn apart by the tire. My ABS light immediately came on as well as Check VSC. I plan on fixing this, but at least I know what that wiring was to under the fender now, lol.
Old 08-25-17, 09:23 PM
  #86
yoitskenn
yoitskenn's Avatar
Nice rare color.
Scraape (08-27-17)
Old 08-28-17, 09:48 AM
  #87
ultm8mind
ultm8mind's Avatar
Damn, so that's what's under there huh, lol? Sucks that happened to you but I guess we gotta pay to play man...
Scraape (08-29-17)
Old 08-29-17, 01:50 PM
  #88
Scraape
Scraape's Avatar
yeah, it definitely could be worse. It still drives fine and all that, but yeah I'll fix the wiring eventually. ABS is good to have
Old 08-29-17, 10:27 PM
  #89
hyphydoms
hyphydoms's Avatar
Seeing yours makes me wish I picked up the blue 98 I looked at. We're looking similar though!
Old 08-30-17, 09:45 AM
  #90
Scraape
Scraape's Avatar
3 wheeling in the low low in the mountains in NC lol
Quick Reply: David's 1998 Lexus Ls400
