JspecVtec ISF
Nice I found it on Amazon for $66.00 I'm assuming this is the same one you are talking about? Amazon.com: aFe 31-10167 Pro-Dry S Black/Gray OE Replacement Air Filter for 2008-2011 Lexus IS-F V8 - 5.0L: Automotive
Car wash after the rain!
Time for MOAR loud! Did anyone recommend you an installer?
-Josh
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
^It might be worthwhile, especially since he has done so many. But if you venture out to my area, there is an installer by the name of Tommy @ MusicBox that does excellent work. I trust him more than I do the dealerships for the most part. He really does a thorough job and gives more than adequate feedback pre, during, and post installation. He's nowhere near as far as Dennis, but I can only recommend the guy who has installed practically everything on my car.
-Josh
__________________
Orange County, CA
Orange County, CA
His name is Tommy or something right? Haha, even I have heard of him and I live in AZ.
ETL Garage did mine as well. Great work....until they looked the wiring harness too close near the piping, causing a total burn and thus multiple CELs. I remember because Pat had the same issue when he had his headers installed. Getting them to work on the car a second time was hard, as scheduling conflicts got in the way with their other projects. For a little more, I should have gone to Tommy, but he corrected everything.
-Josh
__________________
Orange County, CA
Orange County, CA
Just know that when you enter the header territory you'll have a risk of encountering problems with the o2 or a/f sensors connected. You'll run this risk no matter which shop you go to as these sensors are pretty fragile and a code will pop even if some wires are over twisted. My car spat out p0159 and p2241 a few thousand miles after the install. I haven't had a chance to actually check if the wiring or sensor is bad, and can't tell you if it's the fault of the shop or if the sensors went bad as a result of just having headers, but just wanted to at least give you my point of view. My experience with the shop was decent and I saved some bucks with cheaper install. In the end they did a good job and my car didn't have any mechanical problems as a result. Others may have had different experiences.
Different guy, but yeah Tommy is great!. However, the shop in Pomona does have Tommy (Music Box), beat in terms of header install price. Tommy is great and I have him do all my routine maintenance. He gives pretty good attention to detail during his installs and his prices are fair.
That is true, install cost of $500 vs $800 I believe, is a lot of money for other mods :P
-Josh
-Josh
__________________
Orange County, CA
Orange County, CA
I'm one of the guys mentioned that got my headers installed by the shop. The shop's quote is one of the cheapest you'll find in the SoCal area. Their primary specialty is the Mr2 and mid engine cars, but they seem to know what they're doing. By the time I installed my headers with them they had already installed a few others, so they definitely have experience with our car's header install. I personally had no problems before or immediately after the install. They installed the headers with no leaks and the car was functioning perfectly. Just know that when you enter the header territory you'll have a risk of encountering problems with the o2 or a/f sensors connected. You'll run this risk no matter which shop you go to as these sensors are pretty fragile and a code will pop even if some wires are over twisted. My car spat out p0159 and p2241 a few thousand miles after the install. I haven't had a chance to actually check if the wiring or sensor is bad, and can't tell you if it's the fault of the shop or if the sensors went bad as a result of just having headers, but just wanted to at least give you my point of view. My experience with the shop was decent and I saved some bucks with cheaper install. In the end they did a good job and my car didn't have any mechanical problems as a result. Others may have had different experiences.
