Build Threads Details on Club Lexus SC owner vehicles
Lexus SC300 with a 4L80E
Old 09-28-15, 05:43 PM
  #31
Idlefree
Idlefree's Avatar
FFIM from Sleeper design and install by Johnny at Toronto Automotive Repair
Old 09-30-15, 06:18 PM
  #32
Idlefree
Idlefree's Avatar
The engine Bay is just about done, the 2JZ-GE is starting to look better
Old 10-01-15, 06:24 PM
  #33
Idlefree
Idlefree's Avatar
ETS 5" intercooler kit installed
Old 10-17-15, 04:39 AM
  #34
Idlefree
Idlefree's Avatar
Fuses for the two fuel pumps, trans brake and the two coolers for the transmission
Old 10-17-15, 06:39 AM
  #35
Kris9884
Kris9884's Avatar
Right on! This is going to be great. What are the block specs if you don't mind me asking? Turbo specs?
Old 10-17-15, 07:21 AM
  #36
Idlefree
Idlefree's Avatar
Hey Kris9884
Below is what I had done and will be re-doing the engine this winter, my final goal is 1200 to 1400whp I stayed with the 2jz-GE VVTI instead of doing a swap.
Hope this is what you where looking for
Wiseco Pistons
Manley Rods turbo tuff I beam
King main bearings
King rod bearings
King Thrust washer
ARP Headstuds
Engine gasket set
-TT Headgasket
-Lexus seals,washers,o-rings and misc gaskets BC S2 Cams
BC Springs and retainers TMW Turbo kit
- PT6266CEA JB turbo
- ETS Toyota supra full kit - 5" Intercooler
- HKS limit edition blow off valve
- Tial wastegate
- Oil lines and fittings
- Exhaust manifold
- Downpipe
Catback exhaust system
- HKS Dual muffler system Bosch 1000cc pnp injectors DW65c Fuel pump
RMR Fuel rail
PRO EFI 128 FPR W/digital screen
AEM boost gauge
AEM oil pressure gauge
AEM wideband gauge
Gates racing timing belt
Gates timiing belt tensioner
O.E Water pump
Triple A pillar gauge pod
Seibon TS2 Carbon fiber hood
HD9200LXSC-TSII
ISC Coilovers w/swift spring upgrades
Stopech BBK Front
- Rotors
- Red Calipers
- Lines
Stoptech BBK Rear
-Rotors
-Red Calipers
-Lines
Old 10-17-15, 09:54 AM
  #37
LEXOWINO
LEXOWINO's Avatar
This is a beast build man. How many custom parts where made for this.
Old 10-18-15, 04:17 AM
  #38
Idlefree
Idlefree's Avatar
Thanks Lexowino
Way to many custom parts, every time you do something you need to make something custom, and because I stayed with the 2JZ-GE VVTI wiring is a lot more work than I thought. But took her out for a test drive yesterday and she is almost ready to be driven for a couple of month till the engine comes apart.
I really like the way the 4L80E shifts, no hesitation at all exceeds my expectations so far.
Hoping to have her ready for the track on Oct 25 2015
Old 10-25-15, 07:12 AM
  #39
Idlefree
Idlefree's Avatar
Update got car ready on Friday, due to LQ9 plugs over heating and failing the most we could do on the Dyno was 500whp, we could only get 12 pounds of boost. The 4L80e tranny is amazing it shifts smooth quick and no hesitation when shifting and the trans brake is pretty cool. We are changing the coils today and getting another tune tomorrow to get the full boost and true number. I was surprised that the LQ9 did not work properly when the engine gets hot.
Has anyone else had this problem or experience with the LQ9 coils?
Below is a picture of me and my Son getting reading for a meet, we thought it would be cool to join the Supras before heading out together. My Son is the first Sc400 and mine is the Millenium Silver and the Supra people I have met during my build.
Old 10-25-15, 10:28 AM
  #40
gerrb
Super Moderator
gerrb's Avatar
buddy , something is not right .
I really doubt one can do 500rwhp on 12lbs of boost on a PT-6262 and worst on an 4L80e auto transmission which rubs a lot of power.
Old 10-25-15, 11:31 AM
  #41
Idlefree
Idlefree's Avatar
Sorry 496.2 Whp on 12 pounds, and I might of put wrong info its a PTE CEA 6266 turbo not a 6262. You are right the 4L80e robs a lot of power but man it did not feel like it. When you are on trans brake and lauch it is great
Below is the dyno sheet, getting another Dyno done tomorrow hopefully no more issue
Old 10-31-15, 04:14 AM
  #42
Idlefree
Idlefree's Avatar
Final result on pump gas 527whp and 490 torque, with the season ending leaving the car this way. I have been extremely impressed with The 4L80E so far. Gerrb is absoultely right this tranny does juice power from the tranny, but man it shifts quick
Old 11-01-15, 08:53 PM
  #43
jwin
jwin's Avatar
We have had other people have issue with the heat buildup between the cam cover with lq9 coil pack failing so we just use normal 2jzgte coilpack without issues.
Old 11-03-15, 02:26 AM
  #44
Idlefree
Idlefree's Avatar
Thank you jwin, you are right I tried two sets and they both failed, a little disappointing
I put old GM plugs with the coils sitting on top of the valve covers and it seem to work well. When I work on it this winter most likely go with the 2JZ-GTE coils as you suggested.
Old 11-09-15, 09:53 AM
  #45
Idlefree
Idlefree's Avatar
Good Day at the track even it being cold
Quick Reply: Lexus SC300 with a 4L80E
