93 sc400 2jzgte vvti aristo swap
93 sc400 1 jzgte vvti jzx100
He contacted me and I haft to say they guy is a big help. I will definitely use his service for my swap...
One question that comes to mind after doing some reading on the r154 . From what I have seen is that some of the r 154 models don't line up 100% .. I have the sc400 1993 and am using a 98 1jzx jzgte vvti and r154 what kind of problems am I going to run into when mounting the new transmission?
You are going to have to do 6 speed supra TT tunnel to fit the transmission......this is the correct way to do it..
Or you could just cut a hole where shifter comes up through.....
Check out my build thread.....this page should give you an idea of how I did mine...
https://www.clublexus.com/forums/bui...-build-35.html
Sorry guys
well I hate to bum you guys out. I had some problems getting a good 1j so I went with a 2jz get vvti . It's being shipped as we speak and going to try to get harness in to be built by tomorrow ... Now if you guys are still here with me I could use some help. I've herd I can use my sc400 fan still and hers my drive shaft will bolt up cuz it's a auto swap... I'm unsure about the single turbo swap I'm not sure what or how it's all done I'm guessing u can't just put new manifold on and new turbo and it's going to work so was wondering how that works as well . Also I will be out in the junk yard all day Thursday looking for a cluster from a sc300 any thing u guys can throw my way about this swap would be appreciated... Getting a rear sump and mounts soon...
I'm in the process of attempting this swap so far I have gotten the motor and motor mounts a rear sump pan from sc300
Now as far as the water neck sensor I'm not sure what one I need
And how can I use my sc400 hydro fan like tweak did
Also can anybody explain the return fuel line thing
Do I need to do this and if so how
1uzfe is coming out
Motor out
New motor
This is what I think is the water neck sensor hole but no sensor what sensor would I use to make my temp gauge work
1uzfe is coming out
Motor out
New motor
I also went through dr tweak for my new wire harness .. I'm waiting for them to finish it atm but man I tell you those guys are supper cool gotta say thanks to Cam for being so patient with me... I have a feeling putting the new harness on May be a challenge ...
Anyways if anybody know things like power steering and ac and fuel please help and try to be as detailed as can be photos / anything to show what part and how... I would really appreciate it and I'm sure lots of ppl further down the road will also
Here's a good reference I found on another thread.... This is the sc300 pan ... You haft to drill and tap the 2 bolt holes .. The holes are 8m and 1.25 pitch the center hole I drilled out at 20mm
My mid sump 300 pan
The inside of the bottom end
The oil return drilled out tapped and new bolt studs 8m 1.25 pitch and a 20mm center hole
A better picture of the drilled out oil return
And the poor uZ motor in the corner looking lonely .... It's for sale and runs and shifts perfect...
The mid sump pan on the left and the old front sump pan on the right
The mid sump oil pan now on ...hope I did it right the first time no leaks..
Motor mounts I'm going to rock
Next I'm going to jump in this thing and clean it up a bit.. Rework the fuel lines change some stuff to braided steel lines and anything else I can do.... Just herd from Dr tweak they started building my harness today wooooohoooo so stoked to get that....
