SC- 1st Gen (1992-2000)
Hi
Old 07-03-15, 03:05 AM
SC400Weezy
SC400Weezy's Avatar
Default Hi
New to the forum can you guys help me fix this piece of ****
Old 07-03-15, 03:06 AM
SC400Weezy
SC400Weezy's Avatar
Old 07-03-15, 03:58 AM
weirdone
weirdone's Avatar
Hello fellow newbie! What is up with your car?
Old 07-03-15, 07:10 AM
eknine9
eknine9's Avatar
haha, welcome. It doesnt look so bad, whats wrong with it?
Old 07-03-15, 09:05 AM
Teal Sc400
Teal Sc400's Avatar
Just do the courtesy flush...
Old 07-03-15, 10:09 AM
jimmymac30
jimmymac30's Avatar
I'm sure one of us on here can fix it... mind telling us what we are fixing??
Old 07-03-15, 07:05 PM
TXMAG
TXMAG's Avatar
This might be my favorite first post I've ever seen on any of the car forums I belong to.
Old 07-04-15, 01:24 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Doesn't look like a piece of **** to me! Welcome buddy
Old 07-04-15, 07:39 PM
3L4jzz31
3L4jzz31's Avatar
Them s14 wheels look surprisingly good
Old 07-05-15, 11:39 PM
Matromony
Matromony's Avatar
Looks like a clean sc, at first glance i thought it was an s14 and you were in the wrong forums. It makes a lot more sense if it was broke down if it was a nissan lol. Whats the issue with your whip?
Old 07-06-15, 03:40 AM
SC400Weezy
SC400Weezy's Avatar
Thanks bros but yea I have a major issue with the Ingine fan fluid its a bad leak and don't know from where I changed a high pressure hose that cost $150 but wasn't it Andy ideas where the leak could be?
Old 07-07-15, 10:15 AM
Tabaka
Tabaka's Avatar
I make a post like yours everyday, and I've been on this forum for seven years.
Is this a 300 or 400? I'm a little lost on the "engine fan fluid". If you see "fluid" leaking from the large engine fan, it might actually be the waterpump located behind the fan (300).
Old 07-07-15, 03:11 PM
Ali SC3
Ali SC3's Avatar
sounds like the 400 with the hydro fan. its a complicated system that can spring a leak.
just have to find and replace. clean first, then spot the leak.
Old 07-09-15, 07:29 PM
pogoism9
pogoism9's Avatar
This is false. It is not a complicated system. (i'm just ribbing ya)
It can, and will leak though!
That being said. We would be more inclined to help if we had more information than:
"New to the forum can you guys help me fix this piece of ****"
and
"Thanks bros but yea I have a major issue with the Ingine fan fluid its a bad leak and don't know from where I changed a high pressure hose that cost $150 but wasn't it Andy ideas where the leak could be?"
There is a pump, 2 hoses (pressure and return), the fan motor itself, the reservoir, and the tube that runs from the reservoir to the fan pump. Pretty cut and dry for hunting down a leak.
Pro Tip: The fan uses ATF. Your transmission also uses ATF. Make sure it's not a trans cooler line leaking. The fluids look the same.
UnholyAres
12-09-12 11:51 AM
Highclass
03-07-12 07:29 AM
sc300tilt
21
06-03-10 09:02 AM
snikwad
10-21-06 11:34 PM
IS3Mike
Wheels, Tires & Brakes Forum
24
07-28-04 10:05 PM
Quick Reply: Hi
